Go to Post If I thank everyone that I want to, we might be here for a while - Karthik [more]
Unread 24-01-2005, 23:50
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Bumper Classification
OK, we've got a dilemma here, and this may apply to all those folks out there using kitbot chassis.
So, here you go:
We've assembled our Chassis for the Narrow Kitbot Configuration. Our design involves an arm that lifts a tetra in front of our robot. Here's the issue:
If you haven't noticed already, the narrow kitbot can actually drive within the scoring tetras a bit. This can be good, and bad. In our case, its not such a good thing, because if we attempt to lift a tetra while one of the bottom sections is under our chassis, one of two things is likely to happen:
1. The tetra will be damaged/torn apart
and/or
2. Our robots arm will buckle like never before
So, we derived a solution. We've cut two 5x27" "skirts" out of lexan to mount to the front and back of our chassis. These skirts collide with the tetras, rather than allowing them under the chassis. The skirts also provide an opportunity for feedback. The lexan is flexible, so the skirts push inward when up against a tetra. We plan to mount limit switches behind the lexan that allow our bot (in auto mode especially ) to detect when it is up against something.
This is where things get sticky. According to the rulebook, if these skirts are classified as bumpers, they are not legal for use on our robot, because they only leave roughly .5"-1" of ground clearance (those tetras are so low to the ground!).
If they are classified as "bumpers" they are illegal, as R30 states:
<R30> In order to help reduce the impact forces that the robot will experience during collisions with other robots, teams may add external “bumpers” to the robot. If used, bumpers must satisfy the following constraints:
• Bumpers may extend outside the normal robot starting dimensions (in the horizontal plane) up to 4.” per side
• Bumpers must be located in a region from 2” to 8” above the playing field surface.
• Bumpers must not cause the weight of the robot to exceed the weight limit.
• Bumpers must be removable in order to allow the robot starting size to be easily measured during robot inspection.
• Bumpers must be designed to remain attached to the robot for the duration of the match.
• Bumpers and any bumper mounts that extend beyond the robot starting size may not contain “hard” materials such as metal, wood, or hard plastics. The definition of “hard” is one of common sense (i.e., if you can punch it and not hurt your bare hand, it is ok).
Now, as per the part flowchart, if these are not counted as bumpers, they are legal, but if they are bumpers, the ground clearance makes them illegal. This also poses a safety risk for both the field and other bots using smaller kit-style chassis.
My definition is that they would not be considered bumpers. They are functional, as they provide feedback to our robot. They are also not removable, and they are not intended to reduce impact forces with other robots. They also fit within the size requirements without being removed.
They are intended to protect other robots, field elements, and our robot.
What do you think, are we ok?
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 24-01-2005, 23:54
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Bumper Classification
AFAIK, you would only have to count them as bumpers if they extend outside of the 28x38x60 box.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
You are OK. The "skirts" are not "bumpers" as defined in <R30> so there is no problem.
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 24-01-2005, 23:57
Sachiel7's Avatar
AKA: Shayne Helms
Great, Thanks!
I would suggest this to other teams considering a narrow kitbot configuration, it may save your bot (or others, or the field) from alot of damage.
-=Sachiel7=-
Unread 30-01-2005, 18:34
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
The rules say
I take that to mean that our robot with bumpers on it may be up to 36x46. Am I right? Basically the question is does the 4" per side mean we can have four extra inches on each of the four sides of our bot or we get 4" in each direction? As I said before I think it is saying we get 4" on each of the four sides, but I just want some other peoples take on this before we go and build our bot around it.
Unread 30-01-2005, 18:43
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Originally Posted by russell
The rules say
I believe that you have it correct with 4" per side, so 8" total in each direction. But the bumpers have to be within a 6" range for height between 2 and 8" from the bottom of the robot.
See you in DC!
Bumper Specs? M.I. Technical Discussion 1 11-01-2002 18:02
Bumper Sticker Design Preliminaries Robby O Chit-Chat 42 05-09-2001 13:40
Bumper Sticker Tagline Robby O Chit-Chat 14 30-08-2001 20:26
Bumper Sticker Designs Robby O Chit-Chat 11 15-07-2001 11:37
Bumper Sticker Carolyn Duncan Chit-Chat 14 11-07-2001 16:45
