Go to Post Figuring out how to do something is half of the fun. - Mike [more]
  #16   Spotlight this post!
Unread 14-02-2005, 21:47
Josh Siegel's Avatar
Josh Siegel Josh Siegel is offline
lurker
#0448 (Crandroids)
Josh Siegel will become famous soon enough
Send a message via AIM to Josh Siegel Send a message via MSN to Josh Siegel
Re: Globe motor mounting
I used the globe motor like a lathe and turned it down... Hooked it up to a 12V, put the gearhead in a vice, and held a file against it. It fits an FP pinion now, but sadly its too small due to some smoothing files that probably shouldn't have been made. Epoxy stripped twice, what do you think about JB weld on the armature? Would it hold? I cant see easily putting a pin into the FP gear without screwing up some teeth bigtime.
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Globe motor backdrive!! Srkasner Motors 19 08-03-2004 00:10
Globe Motor archiver 2000 4 24-06-2002 00:15
So you want to stall a Globe Motor... archiver 2000 1 24-06-2002 00:09
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
