Go to Post You can make unfounded guesses, but chances are you'll come off looking like a moron. Let's try and avoid that. - Karthik [more]
Unread 25-01-2005, 16:39
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
camera power supply
where does the cmucam get its power from when hooked up to a serial port? I was thinking through the serial cable, but it doesn't show a positive terminal in the diagram on the serial cable. do you know where it gets power from when running the cam from the serial cable with an emulator (to install and test the firmware)? thanks for the help.
-Stephen
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
need Computer power supply trick Tytus Gerrish Electrical 7 20-01-2005 11:25
12V Power Supply Feeds My Robot MikeDubreuil Electrical 17 31-03-2004 12:06
operator interface power supply hi_im_sean General Forum 1 05-02-2003 14:50
power supply of control system archiver 2000 5 24-06-2002 00:14
