Go to Post stop whining about something that can be solved by working harder. - artdutra04 [more]
Unread 25-01-2005, 20:31
farmer farmer is offline
Tired Mentor
AKA: Matt
#1108 (Panther Robotics)
farmer is an unknown quantity at this point
Where to insert code?
Ok new FIRST programmer here.....where are we allowed to insert code. For example, we want to change the sensitivity of our joy stick drive by using an array (we think). Does this go in user_routines.c ? and if so, does it matter where?
Unread 25-01-2005, 22:01
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Where to insert code?
You put your actual code to drive the robot in user_routines.c, in the Default_Routine function. Using some math functions you should be able to change the sensitivity of the joystick.
http://www.mikesorrenti.com/
Unread 25-01-2005, 22:50
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Yeah, what he said. You are going to want to study it some because the default code uses somthing called limit mix at least for the one joystick drive. I forget what it does but I think it had something to do with making sure that your pwm values did not exceed 255 or go below 0. Or something.
Unread 26-01-2005, 00:21
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Files that you aren't supposed to modify are clearly labeled in the comments at the top of said files. The most common places of adding code are in user_routines.c (usually for driver code), and user_routines_fast.c (for autonomous, and processing interrupts and the like). In these files, you will find a comment to the effect of:
Code:
/*Add your code here.*/
If you put your code there, you are much more likely to get the results you expect.
What the limit mix functions do is take the values of the x and y axis of the joystick, and convert them to the numbers that you would want the motors to do. It's just a little bit of math.
Yep... using a math formula is a much better idea than using a lookup table, which would be horribly inefficient with the limited resources we have. See this post for one example.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 26-01-2005, 23:43
Tired Mentor
AKA: Matt
Thanks everyone! Yeah I put in an array table but thinking about using a log formula instead. I keep getting an error when building -
MPLINK 3.90 Linker
Error - section ' .idata_user_routines.o' can not fit the section. Section ' .idata_user_routines.o' length=0x0000020c
Errors :1
Unread 27-01-2005, 00:10
Fat Alex's Avatar
Fat Alex Fat Alex is offline
Mr. super uber ultra Alex
AKA: Alex
#0060 (Bionic Bulldogs)
Fat Alex is on a distinguished road
Send a message via MSN to Fat Alex
MPLINK 3.90 Linker
Errors :1
if your array table does not change you could dosomething like:
rom const char myArray[2] = {1, 2};
the problem is you don't have enough memory in RAM for whatever array you have.
note: ya can't change it if its rom
and another: go to http://www.chiefdelphi.com/forums/sh...ad.php?t=33359 for more info
Shake the hand that shook the world
Unread 27-01-2005, 23:51
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
I disagree.
Depends on how complex the math is I guess, but using ROM to store your loo up table yields pretty fast results.
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
A Centralized Code Dump? colt527 Programming 29 01-01-2005 16:07
heres the code. y this not working omega Programming 16 31-03-2004 15:18
