Go to Post Grease your gearboxes folks! Gears need grease, otherwise they kerplode. - s_forbes [more]
Go Back   Chief Delphi > Other > Math and Science
Thread Tools Rating: Thread Rating: 9 votes, 4.89 average. Display Modes
Unread 27-01-2005, 17:46
UsmanB UsmanB is offline
Michigan Wolverine CO/2009
None #0123 (123 Cosmos)
UsmanB will become famous soon enough
Re: Stupid physics problem.
ya i know i probalby did somethign wrong, some how when i did cos 34 i kept getting an negative number :S oh well i was close! im taking my first high school physics class right now
Unread 27-01-2005, 21:26
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You probably have your calculator in radians mode and not in degrees mode. A common error.
Unread 27-01-2005, 21:44
Stephen P's Avatar
Stephen P Stephen P is offline
Team Role: Mechanical
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
For the box one, remember that
f = uN (N is normal force, perpindicular to the slope, pushing up on box)
To find normal force, resolve the weight (mg) of the box into components perpindicular and parralel to the slope, by taking the sin and cos of the angle.
F = ma = "forwards minus backwards and up minus down"
In this case, the weight vector parallel to the slope is the forward, and is being impeded by the backward force of friction (f = uN).
You might find it handy to know that whatever the mass of an object,
tan(@)= u (u is frictional coefficient, @ is angle of repose, the angle at which something begins sliding)
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 27-01-2005, 22:06
yep u were right thought about that but was too lazy to check; checked it now and worked.
Unread 28-01-2005, 04:25
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
heh someone bet me to it ...
The difference is a lot lol....
cos34° = 0.8290375726...
Cos34(rads) = -0.8485702748...
F is actually Frmax remember...
If its in limiting equilibrium, Then the friction is up the slope, and a componant of gravity is down the slope. So along the slope, you get
mgsinα=Frmax
and at a right angle, you have the reaction vs the other componant of the gravitational force. Thus - mgcosα=R
Since Frmax=μR, μ=F/R, so you get mgsinα/mgcosα=μ=tanα
Assuming the object is in Limiting Equilibrium . It will not give you the correct value of μ otherwise it will be lower.
I've attached a little diagram i did in paint.
I am actually studying double maths so i hve done 2 mechanics modules, and doing the final one in a month lol...
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 02-02-2005, 01:07
mr_spam mr_spam is offline
Kenny B
AKA: Brendan
FRC #1410
mr_spam is an unknown quantity at this point
Send a message via AIM to mr_spam Send a message via MSN to mr_spam Send a message via Yahoo to mr_spam
The entier first problem is also completely ignoring the rotational inertia of the pullies and the streching of the rope that would occur.
Unread 11-02-2005, 06:20
Gasperini's Avatar
Gasperini Gasperini is offline
Mechanical Engineering Student
AKA: Kevin
#0968 (RAWC)
Gasperini is a jewel in the roughGasperini is a jewel in the roughGasperini is a jewel in the roughGasperini is a jewel in the rough
Send a message via AIM to Gasperini
Right with the friction. My dynamics professor would always trick the class with that. MAXIMUM friction is Mu*Normal force. ACTUAL friction can be less. Remember that when you solve, because it can make equilibrium seem a little wacky. (I'll catch it when I put in numbers and get two answers for the same variable. Watch vector components that appear in both X and Y directions... You can catch errors with them.)
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
Funky Physics problem. Elgin Clock Math and Science 4 29-09-2004 13:00
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
