Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
Unread 29-03-2002, 09:23
Mark_lyons Mark_lyons is offline
#0157 (Aztechs)
Mark_lyons is an unknown quantity at this point
Question Pre-Match/Post- Match Pit Routine
I am curious about what other teams do prior to sending their robot out for a match, or what they do once a match is over.
We normally bring our robot back and do both an electrical check and a mechanical check of all our sytems, regardless if we used them in the match. We have two pit teams, electrical and mechanical. Each with their own checklist. If a problem is found, only designated pit members are allowed to repair the robot. Everyone else MUST leave the pit area.
We do this for a number of reasons, but most importantly to minimize the 'panic attack' if something were to go wrong.
I bring this up because I see way too many teams, when in the pit making repairs, out of control. I think more teams ought to adopt some sort of 'Pit Policy', to eliminate making a bad situation worse because of panic.
Unread 29-03-2002, 10:14
Jgreenwd1's Avatar
Jgreenwd1 Jgreenwd1 is offline
The Grasshoppers
AKA: jeremy
None #0095 (LRT/UVR)
Rookie Year: 1998
Jgreenwd1 is an unknown quantity at this point
Send a message via AIM to Jgreenwd1 Send a message via Yahoo to Jgreenwd1
same here
last year on team 95 we did the same thing we brought the robot back and did a cheack list.
but we didn't have two pit teams we had one, it was about 4 team members that knew the best about the robot in each area, and one of them was named the pit crew cheif, he made sure that made sure every thing was done right. if we needed help fixing the robot we would have a choach come and help use.
i tried to get somthing like your pit policy, but coulded.
but i dont know what they do this year. i handed it over to some one else.
-Jeremy Greenwood
Everyone loves The Grasshoppers
life is a party and partys never end.
Unread 29-03-2002, 12:48
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Seeding matches:
1) Repair robot
2) Get into line
3) Repair robot in line
4) Pump pnumatic pressure
5) Enter pit area
6) Decide what we can/can't do
7) Play match
8) See what broke
9) Wheel back to pit
10) Repair robot
Cycle continues
Elim matches:
1) Get into line
2) Verify we didn't miss anything
3) Continue running through match strategy
4) Wheel robot in
5) Play match
6) See whats broken
7) Fix robot
8) Play match
9) See whats broken
10) Tightnen chains
Cycle continues until we are eliminated.
I believe in NYC we played a match where nothing broke... we were clueless on what to do... I think we tensioned chains.
Pit crews can work, and they can't work. I feel everyone who wants to be involved in the pit should be. Luckly in my team it came down to who WANTS to be in the pit, nah we weren't stressed. Our 130 pound robot (after removals) and malfunctioning goal gripper was lots of fun.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 29-03-2002, 19:51
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
team 365 pit
Here is what life is like in the MOE pit (hopefully it won'f be like this at nats)
1 Fix wings
2 Keep fixing wings
3 fix wings some more
4 make sure everyting works (if time allows)
5 get into line
6 set up robot
7 play match
8 repeat steps 1-7
Unread 30-03-2002, 10:44
aka Scott White aka Scott White is offline
#0555 (Montclair Mounties)
aka Scott White is on a distinguished road
Pit Routine
The first thing we after getting the robot back to our pit is try to identify what broke, usually the bearings were popping out. Then we attempt to fix the problem usually by wedging a piece of wood and thin strips of metal against the bearings. Then the battery gets replaced with the one we had charging. Then we pull the harpoon up, and build up some pneumatic pressure. At this point, they have already made the final call for our robot, so we begin the 60 yard dash to the line, where we continue to try to fix anything broken.
The 3 magic ingredients are
Trust, Love, & Magic.
"We brake for broken speed controllers"
I love the the smell of melting speed controllers in the morning...
Unread 30-03-2002, 15:52
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
422's pit stops
We actually have a sturdy 'bot, so we're not always doing repair jobs and the like. But this is usually the routine:
Before a match:
1) Run a systems check to determine if both drives can move easily and the goal grabber... grabs.
IF (systemscheck == good)
2) Sit around for 10 or 15 minutes because we did the check
far too soon.
else
2) Scramble like mad to tighten things, crimp things, electrical
tape things, and wire-tie things to state of functionality
After a match:
1) Pick up the panels that have fallen off the robot and onto the field. Try to rub off the tire marks left by other robots driving over them repeatedly. Replace panels by leaning them against the robot and velcroing them back down.
2) Call down our engineer and reassure him by saying "The drive train still works, no chains popped, the motors are cooling, everything will be all right"
3) Run another systems check and fix whatever electrical problems we might have. Mechanical has never broken down (goal grabber and the motor mounts/chains/motors themselves have never needed serious adjustment)
That's about it. The only serious problem we've ever had was our left drive random stopped working electrically one match, and when we took it back to the pits we found 3 different reasons the circuit couldn't complete on it (PWM cable, victor-to-plug wire, plug-to-motor wire).
-Gui
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 31-03-2002, 02:36
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
We mostly just check all of the connections and stuff (pneumatics, speed controllers, etc). Then before the next match we tether up the robot and make sure everything is functional...
Unread 31-03-2002, 10:06
Kit Gerhart's Avatar
Kit Gerhart Kit Gerhart is offline
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Rookie Year: 1996
Kit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond reputeKit Gerhart has a reputation beyond repute
Send a message via AIM to Kit Gerhart
After a match, we do the following in the pits:
1) Inspect for damage and repair and "tweak" if necessary
2) Tether the machine and:
2a) Place machine in proper gear for next match and make sure transmissions are engaged
2b) Reset goal grabber to "start" position (angled up so robot will be <36 inches long)
2c) Reset ball basket
3) Change battery and put previously used battery on charge
4) Check switches on operator interface for proper position for start of match
5) Repeat 1, above
While in line for next match the following usually occur:
1) Tether machine and check battery voltage reading to double or triple check that we have installed a fully charged battery
2) Recheck settings of operator controls
I've probably forgotten something, but this is pretty much what we do between matches.
Team 45, TechnoKats, 1996-2002
Team 1062, The Storm, 2003
Team 233, "The Pink Team," 2004-present
The views I express here are mine, and mine alone, not those of my team, FIRST, or my previous teams.
Unread 31-03-2002, 10:20
D.J. Fluck
Posts: n/a
at the first regional, while we still are selecting our drivers, the coach, whether it is andy b or someone else, goes through and does a post match analysis, it has multiple factors like "Ability to follow commands" and stuff like that. Then your are commented and rated. After the drive team and HP are rated, the students go through and rate the coach and how well he did.
Unread 31-03-2002, 10:47
Rookie Year: 1996
We also evaluate the robot
As DJ stated, we evaluate our drivers and coach (coaches back when I was one.) We also evaluate the operation of the robot, including the drive train, the ball collection system, and the goal grabber. Andy came up with a form for doing this two or three years ago, and it has worked well.
Unread 31-03-2002, 11:14
#0157 (Aztechs)
Interesting.. First of all, are your coaches adults or students? Does your coach have any specific responsibility during a match? If so, what are they?
Unread 31-03-2002, 12:14
Rookie Year: 1996
There are varied opinions on whether coaches should be adults or students, but our coaches have always been adults. This year our coach, and lead engineer is Andy Baker.
Our ultimate goal would be for the coach to say nothing during a match, except to maybe count down time for a last-second return to our end zone. In reality, with the help of the human player who helps keep track of the score, the coach makes strategy decisions during matches and gives instructions accordingly. As the season progresses, more and more of these decisions fall on the drivers. Am I stating this correctly, Andy.
During three of the years that we had two coaches, I was "driver/operator coach" and was mainly responsible for watching the performance of our robot and giving instructions related to performance issues with the robot. Part of my job was also to work with the drivers in making sure the robot was "ready to go" at the start of the match.
Also, as sort of "captain of the ship," part of our coach's job is to take responsibility if something goes wrong during a match. We try very hard to avoid situations where a student driver is "blamed" for mistakes made during a match.
Unread 31-03-2002, 12:33
asher asher is offline
None #0031
Rookie Year: 2000
asher will become famous soon enough
Our coach is ALWAYS a student, we never felt the need for an adult, and in my experience they cause they most of the problems on the field (yes, I know not all adult coaches do this, but in general they create issues) If you do have an adult coach they should work well with kids and have enough respect for the kids to listen to them, you'll often run into the "well, I'm more experienced so you'll do what I say" when a student may have a better idea.
Unread 31-03-2002, 13:43
Robogeek
Smile
Our coaches have been and always will be students. This year we have a guy devoted entirely to scouting and coaching - he spends all of Thursdays scouting other teams at practice and getting their strengths and weaknesses. Then he transfers his database on all the teams he's seen to someone else equally competent for modifications on Friday, while coaching off of his old database to me (the driver). After each match we play, he synchronizes his database with the person in the stands', and we start over.
Since our robot is simply designed, our secondary controller only has to work two buttons (one to turn off the compressor's automatic cycles and one for the goal grabber), and therefore the job can pass between team members. We have 3 or 4 good shooters, so they rotate as well. Thomas (our coach) and I usually visit our alliance partners' team normally 20 to 30 minutes in advance to coordinate what we're going to do, get the most up-to-date scouting we can about the people we're paired against, and talk strategy from the 15 minute mark down. Thomas then keeps track of the overall gameplan in his head, I keep track of what our robot has to do in my head, and we work together with the other team through the match.
We've never seen a need for adults to be our mentors in a match, and they've never seen the need either. They're content to be teachers and let us learn on our own sometimes.
Gui Cavalcanti
  #15   Spotlight this post!
Unread 31-03-2002, 15:19
DaveO'B365's Avatar
DaveO'B365 DaveO'B365 is offline
FRC #0365 (Miracle Workerz/MOE)
Rookie Year: 2000
DaveO'B365 is an unknown quantity at this point
Send a message via ICQ to DaveO'B365 Send a message via AIM to DaveO'B365
Just a bit more than that, Joe...
As a Member of the Elite MOE Pit hehe... i can say that the first thing we do is run around and find out what went wrong, if anything, and then we prioritize quickly, we have a small team work on each area, mainly our wings(each side). we would basically replace and repair each damaged component after each match, and, i think i'm entitled to brag that we constructed an almost entirely new wing after one match in which we had a bit of a problem. after we fixed/replaced our stuff, we would reset our pneumatic systems and release our various braking systems so we could move at the beginning of the next match. and last, but certainly not least, we'd get a fresh battery, and arrive to the queing area fashionably late, and just on time to not be disqualified.
Dave- the self-proclaimed best student hack-sawer on 365...
Insanity is relative.
"Like olympic medals and tennis trophies, all they signified was that the owner had done something of no benefit to anyone more capably than everyone else."
-Catch 22
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
Pre -Inspection and IMPORTANT Notes. Mike Martus Off-Season Events 1 07-11-2001 03:19
