Go to Post It's wrong to scuttle someone else's boat because you don't think it's seaworthy. You probably don't know that what you were seeing will be called a submarine. - ThatHat [more]
Unread 27-01-2005, 23:15
mohrr mohrr is offline
Rookie Year: 1957
mohrr has a little shameless behaviour in the past
Initialize_Gyro() failing
My team is calling Initialize_Gyro() from user_routines.c:User_Initialization(), as shown in the documentation, and our controller seems to hang after the call. We can't seem to find anything in any of the code called by Initialize_Gyro() that would cause something like an infinite loop, but a printf after the Initialize_Gyro() line will not print. If we remove the line, it will.
We spent a good hour or so today trying to find out what we're doing wrong without luck. If you had a similar problem with the Gyro please respond. Either way, I'll be posting Saturday with either a more detailed description of the problem or, hopefully, instructions on how to fix it.
The Role of the UN Lisa Perez Chit-Chat 24 30-05-2004 15:02
Failing analog inputs? Phasmatis568 Control System 5 22-01-2004 13:28
