Go to Post When you tell any of your kids that winning isn't important, or isn't [I]that[/I] important, the flapping sound you hear is your credibility flying away. - jlindquist74 [more]
Unread 29-01-2005, 14:04
hayakuneko's Avatar
hayakuneko hayakuneko is offline
AKA: Joshua
FRC #0696 (Circuit Breakers)
hayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of lighthayakuneko is a glorious beacon of light
Send a message via AIM to hayakuneko
Exclamation Gear Coupling for Jideco Window Motor
The N-D Gear Coupling on the First CAD Library (www.firstcadlibrary.com) is made for the Nippon Denso window motor. If any other teams have created a gear coupling for the Jideco motor, I was wondering if it would be possible for me to get the inventor model of it. If not, would you know where I could get one?
Would we need to machine it? or would a team be willing to sell it to us?
Thanks,
Team 696
Unread 29-01-2005, 14:29
J15.5h's Avatar
J15.5h J15.5h is offline
#1247 (ROKS)
Team Role: Mechanical
J15.5h is an unknown quantity at this point
Re: Gear Coupling for Jideco Window Motor
I am not 100% sure what you are asking, however, the Nippon-Denso Motor Coupler (2 are included in the kit) is made for the Nippon-Denso Window Motor and I BELIEVE that it also fits on the Jideco Window Motor. There is one Jideco and one Nippon-Denso Window Motor included in the kit, and two couplers included in the kit. (2 couplers divided by [1 Nippon-Denson Moter + 1 Jideco Moter]= 1 coupler per motor).
- I hope this helps!
Unread 29-01-2005, 15:02
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
One of the motors is a 9 teeth and the other one has only 8, so the couplers only work for one motor.
David
Unread 29-01-2005, 18:03
NeedMoreEngines's Avatar
NeedMoreEngines NeedMoreEngines is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Driver
NeedMoreEngines has a spectacular aura aboutNeedMoreEngines has a spectacular aura about
Send a message via AIM to NeedMoreEngines
Thanks,
Team 696
You guys wouldn't happen to know what kind of car the Denso motor is from? (That's the black one right?) Or do you know where I can find that out?
Thanks
Mike F.
Team 1279
Unread 30-01-2005, 18:35
hayakuneko's Avatar
AKA: Joshua
Thanks for trying to help me out, but my team has now decided that the Jideco motor has no use... and is not important this year.
Thanks.
Mating gear for the window motor? nwbutterfly Motors 2 24-01-2005 10:53
Coupling the drill motor with out the 15 tooth gear Chopper_Dave Motors 1 17-01-2004 01:06
DP of Window Motor Gear? archiver 2001 9 23-06-2002 23:24
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
