Go to Post I will test first 'cause you cannot learn unless you break something first! - Andy Brockway [more]
Unread 29-01-2005, 15:18
evil666 evil666 is offline
Lucifer
evil666 is an unknown quantity at this point
Exclamation Default Code editing
[font=Times New Roman]How do you get the default code to work with two joysticks?
Accept Satan. He is your God.
Victors, Default code, & joystick configuration Vermatitis Control System 4 27-01-2005 16:01
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
heres the code. y this not working omega Programming 16 31-03-2004 15:18
Strange IR sensor movement with default tracker code wun Programming 5 19-03-2004 10:51
Is default code already loaded? quickie25 Electrical 8 19-02-2004 22:51
