Go to Post Our team is using a video camera with frame-by-frame analysis to figure out all the characteristics of the foam ball. If the Boeing engineer says it's possible, I'm going to believe him. - sciencenerd [more]
Unread 29-01-2005, 16:40
CmptrGk's Avatar
CmptrGk CmptrGk is offline
Programming Mentor
AKA: Dillon
FRC #0716 (Who'sCTEKS)
CmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud ofCmptrGk has much to be proud of
problem with void Process_Data_From_Local_IO
ok, this has been sort of annoying, mplab says that there is a syntax error in this line void Process_Data_From_Local_IO(void) this to me makes no sense whatsoever. also, it says that there is a syntax error on the last line of the program which is completly blank. here is the problem code
Code:
 * FUNCTION NAME: Process_Data_From_Local_IO
 * PURPOSE:	   Execute user's realtime code.
 * You should modify this routine by adding code which you wish to run fast.
 * It will be executed every program loop, and not wait for fresh data
 * from the Operator Interface.
 * CALLED FROM:   main.c
 * ARGUMENTS:	 none
 * RETURNS:	   void
 	  if (p3_sw_aux1 == 0 && p3_sw_top == 0 && p3_sw_trig == 0)
 		   auton_state = 1;
 	 else if (p3_sw_aux1 == 1 && p3_sw_top == 0 && p3_sw_trig == 0)
 		auton_state = 2;
 	else if (p3_sw_aux1 == 0 && p3_sw_top == 1 && p3_sw_trig == 0)
 		auton_state = 3;
 	  else if (p3_sw_aux1 == 0 && p3_sw_top == 0 && p3_sw_trig == 1)
 		auton_state = 4;
 	  else if (p3_sw_aux1 == 1 && p3_sw_top == 1 && p3_sw_trig == 0)
 		auton_state = 5;
 	else if (p3_sw_aux1 == 1 && p3_sw_top == 0 && p3_sw_trig == 1)
 		auton_state = 6;
 	 else if (p3_sw_aux1 == 0 && p3_sw_top == 1 && p3_sw_trig == 1)
 		auton_state = 7;
 	  else if (p3_sw_aux1 == 1 && p3_sw_top == 1 && p3_sw_trig == 1)
 		auton_state = 8;
"Great autonomous mode Dillon."," It hasn't been written yet"
after an Archimedes match
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Physics Problem Venkatesh Math and Science 13 30-11-2004 20:30
heres the code. y this not working omega Programming 16 31-03-2004 15:18
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
