Go to Post [You know you've overdoes on FIRST when...] You're willing to take an 8 AM for the team. - ttldomination [more]
Unread 29-01-2005, 19:16
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Controller disables itself after being reprogrammmed
For some reason our robot controller started automatically disabling itself every time it gets programmed, i.e. the rc mode light starts blinking red and the robot does not respond until it is reset using both the reset and programming buttons. I am running the new master code and the same thing happened with the previous master code version. It seems to have started doing this for no reason that I can determine. Has anyone had this problem and/or know how to fix it? I have searched the forums and I couldn't find what I was looking for, it doesn't seem that anyone has had this problem where it disables itself every time the rc gets reprogrammed.
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
2003 robot controller & interface LGuY Control System 3 04-04-2004 16:01
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
