Go to Post [A screen shot] is very helpful - I've sent Brandon many of those the various times I've broken ChiefDelphi.com! - Jessica Boucher [more]
Unread 29-01-2005, 23:57
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Kitbot transmission plate
I am seeking some input on the structural support of the kitbot transmission plate. I am contemplating options to cool the CIM motors and would really like to blow the air vertically rather than horizontally across the motors. The plate really interferes with that preference of mine. How much structural support does it supply? Can I achieve the same purpose by using two 1" angles of aluminum. The large fan fits perfectly between them using the bolt pattern on the transmission boxes. I have not weighed the plate and compared that to the angles. What does the plate offer in support that two angles could not provide?
Is there any advange to keeping the plate and removing a 3 or 4 inch hole for the air flow from the fan?
Thanks,
APS
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 30-01-2005, 00:51
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Kitbot transmission plate
Actually...why would you 'have' to cool the motors? They're good motors and they havn't burned out. We actually raised our robot and had it go full speed foward and had the wheels run for lik, 20 minutes or so and the motor didn't even get warm.
Unread 30-01-2005, 01:30
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
At the point your CIM's get warm to the touch, they're probably flaming hot inside; the CIM's have a pretty thick metal casing. And like what Stonefan said, the CIM's are pretty robust motors.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 30-01-2005, 01:37
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
You could always cut it short or use different supports(prefrebly L or C channel aluminum extrusions) mounted underneath the transmissions. They have three rows of those slip holes, and atleast one depending on your set up should be overhanging on the inside of your robot. Should work well for what you need.
Team Website
Unread 30-01-2005, 02:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
That's exactly what I'd expect to happen, given you're running them under no load.
Run them near stall and they'll get hot a lot faster.
But like has been said many times before, by the time the surface of the motor gets hot, you've damaged the internals of the motor irreparably.
2001-2004: Team 100
2006-Present: Team 254
Unread 30-01-2005, 02:07
Jeff K.'s Avatar
Hmm..now what?
Okay i also forgot to say that before we had the robot running with the electronics, we actually had a guy make a backing for it and a 90 lb guy, short light guy, was sitting on it, and we also had a 160 lb guy on a rolling chair tugged by the robot and went across our football field, also getting all of us in trouble. It was sorta cool, not very smart though, and the motors are still in practically perfect condition. They weren't hot at all from towing about give or take 150 pounds. We also had them getting currect directly from the battery, also not very smart...so ya. I've found old CIM motors in our closet and people have dropped them quite a few times and they still run as if they were new...well...sorta...but they're okay. But those CIM motors are really powerful and also very durable.
Unread 30-01-2005, 11:54
Red face Re: Kitbot transmission plate
I don't know if our CIMs will heat under a load yet. I am anticipating that they might.
What I am hearing from replys to this and another post is that adding a cooling fan outside the case of a motor is of no consequence. Cooling by an external fan does nothing to prevent damage inside.
http://www.chiefdelphi.com/forums/sh...ad.php?t=33313
I can't say if we have our transmission geared correctly in the power curve but am trusting the FIRST volunteers who designed the kit transmission. We are using the unmodified stock kit componants with the 8" x 1" wheelchair casters in a four wheel drive configuration.
I still consider it prudent to add some air movement to aid in the radiant cooling of the motor cases. I will not consider it a top priority in the design and just find a location to intall a fan to get some air moving in the vicinity of the motors.
Thanks,
APS
APS
Founder FRC 499
Unread 30-01-2005, 12:35
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
The gearing this year is definitely adequate to prevent excessive heating. The final ratio (counting the sprockets, not just the transmission) is 17:1 I believe. Last year we ran successfully with a 13:1 ratio, the motors would barely be warm after 10-15 minutes of driving around. They even moved the bot around with a 4:1 ratio, but they were definitely too hot then.
Unless your going back and forward quickly, or in a shoving match for most the 2:15 I would expect the motors to be fine for the match and quite a bit afterward.
Unread 30-01-2005, 12:51
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Why is it that people keep saying that? Even at a reasonable load, the motor can easily be outputting 100+watts of heat. Even if the motor can radiate that safely itself, it is going to be hotter (significantly) than if it had some active cooling. Now say you do have a short spike in heat output. We can all agree that we would much rather have their cooler motor to start with spike, then the hotter one.
Sure its a bad idea to rely soley on cooling in your design to protect your motors, but you can definitley get more out of your motors if you cool them.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 30-01-2005, 14:34
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Max,
Run some numbers and I bet you find that the CFM of the fan vs. the radiating effectiveness of the motor case cannot get rid of 100 watts. (actually, if you are running the kitbot trannys then it is more like 250w/motor @ 40 amp input) If you blow air on the wire end of the motor (this is the end with the brush assy.) you may reduce the case temperature a little. If you were to add cooling fins and fan, you might be able to get the outside of the case down to ambient but there is no direct thermal connection to the armature where much of the heat is generated. If you end up far enough under wiegth to add fans, my bet would be on blowing them at the wire end of the motors. It might not do much, but if it makes you feel better than do it.
Al
WB9UVJ
www.wildstang.org
________________________
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
Gearbox Lord Nerdlinger Motors 20 15-07-2003 00:38
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
