Go to Post instead of complaining, suck it up, think a little harder, and make the most of what you do have. - Andy Grady [more]
Unread 30-01-2005, 16:42
Rod's Avatar
Rod Rod is offline
Mentor
FRC #0662 (Rocky Mountain Robotics)
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
pic: Team 662 05 Dirve Train 2
-Rod-
Team 662
Colorado Springs, CO
Unread 30-01-2005, 16:45
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
Re: pic: Team 662 05 Dirve Train 2
Looks great! I love the custom wheels. Very nice. How fast is it geared to go? And how much, if at all, did you lower the center wheel?
On a separate note, this year appears to be the year of the 6 wheel. It worked so well for 254/60/22/etc I get the distinct feeling that we will see a lot of 6 wheels in 05'
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 30-01-2005, 16:55
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
sweet, i remember your inventor drawing for 6WD awhile ago, good too see it actually come into affect this year! see ya out on the field.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 30-01-2005, 19:00
Rod's Avatar
Rod Rod is offline
Mentor
On a seperate note, this year appears to be the year of the 6 wheel. It worked so well for 254/60/22/ect I get the destinct feeling that we will see alot of 6 wheels in 05'
Speed 7.6 FPS Center wheel is 1/8" Lower
-Rod-
Team 662
Unread 30-01-2005, 19:53
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Which would make your ground clearance what?
Looks like less than 1/2" ..
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 30-01-2005, 20:03
Rod's Avatar
Rod Rod is offline
Mentor
Ground clearance is 1/2 in center, 3/8 front and back. Wheels are 5" Dia. We are going to make 6" wheels this week.
-Rod-
Team 662
Unread 30-01-2005, 23:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I like the "smallness" of the gearboxes and how they fit back to back so well with lots of space between. What does the 55 lbs include (electronics and battery too?) Also, how thick is the sheet metal?
Unread 31-01-2005, 08:56
Rod's Avatar
Rod Rod is offline
Mentor
55 LBS as shown (includes Battery) sheet metal is 1/16"
-Rod-
Team 662
Unread 31-01-2005, 09:12
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Rookie Year: 1999
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
We had 1/16" thick chassis channel like that last year, I hate to tell you but the perimeter got the living #$#$% beat out of it. It caved in like a tin can, and not even in rough play. We ended up putting 1.5x1.5x1/4 angle around the top, on the front and back. That helped but even that got caved in. You might be OK if you put a bunch of noodle foam around it. Also having those wheels outside the envelope without some kind of fenders or protection might get the shafts bent when you take a side smacking. Sorry if I'm annoying you, just want to be helpful.
But other than that, this is a very clean nice design, nice light gearboxes. G/L
www.179swampthing.org
Unread 31-01-2005, 11:09
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
is that got the back 2 and the front wheel powered seperately? i can't see that well lol
looking nice though, good/bad to see that other teams have got lots built
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 31-01-2005, 11:39
Rod's Avatar
Rod Rod is offline
Mentor
Frame is 1/8" bottom pan is 1/16'
-Rod-
Team 662
Unread 31-01-2005, 11:44
Rod's Avatar
Rod Rod is offline
Mentor
It is tank drive. The three wheels on each side turn together.
-Rod-
Team 662
Unread 31-01-2005, 12:38
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
I am pretty sure 254/60 did this with a high degree of success so I wouldn't be too worried. BTW it looks very nice and well organized.
Penn Class 08
Unread 31-01-2005, 13:08
Unsung FIRST Hero
Bill Gold Bill Gold is offline
Retired -- 2006
Rookie Year: 1999
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
60/254's four corner wheels were protected with a roundstock bumper that spanned the full width limit in the front and rear last season. Check old pictures on CD and on teams' websites if you want to see how it looked.
-Bill
  #15   Spotlight this post!
Unread 31-01-2005, 14:44
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
The gearbox was made like that just because of last year's box, it was a royal monstrosity, took forever to build, and weighed a ton. We deliberately tried to stay away from that this year.
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
