Go to Post It's important to know that it isn't always best to have biggest machine out there. - Quatitos [more]
Unread 30-01-2005, 18:29
wmurphy wmurphy is offline
#1529 (Cyber Cardinals)
wmurphy is an unknown quantity at this point
Joystick Modification Question
I wasn't sure the "best way" to temporarily mount the joysticks on pressboard, but I came up with the following method. We took the bottom plate off the joysticks and drilled 4 holes. Then we put 4 machine screws (heads on the inside of the bottom plate) and fastened them with nuts on the outside of the bottom plate - leaving 4 threaded shafts protruding. Can't remember if and when we used washers .... Note: Before we put screws in the holes, we used the bottom plate as a template on the pressboard in order to mark the holes we needed to drill in the pressboard. Then we simply reassembled the joysticks (which now have 4 threaded studs coming out of the bottom plate) and pushed the screws through the holes in the pressboard. Next, we put 4 additional nuts on them to hold the joystick(s) in place.
Question: After doing this, I think I read or heard something about NOT modifying the joysticks??? Was the "spirit" of not modifiying them ONLY related to the movement of the stick and / or electrical connections? OR .... is what we did in order to mount them considered an "illegal modification"?
"MURF"
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
yet another joystick question Stormhammer Rules/Strategy 2 19-01-2004 10:10
question about one joystick drive programing james700 Programming 13 29-01-2003 14:49
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
Alternate Joystick question archiver 2001 5 24-06-2002 00:01
