Go to Post Technology is everywhere, yet the human factor is what makes an event special. - synth3tk [more]
Unread 31-01-2005, 10:17
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Extending 6 Gauge Wire - Best Practices?
The ground wire on the Andersen connector is too short. I can't get it reach our breaker panel, and without the need for a ground stud like last year's multiple breakout setup, I want to avoid using one.
What are the best practices in extending the 6 gauge wires on the Andersen connectors? Splice? Bolt two lugs together, and wrap in electrical tape? Break down and make space to mount a ground stud for just two wires?
How do you do it?
-SlimBoJones...
Unread 31-01-2005, 10:31
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Extending 6 Gauge Wire - Best Practices?
Why not replace the entire wire with one long enough for your needs?
Unread 31-01-2005, 10:34
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
FRC #0254 (The Cheesy Poofs)
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
We usually pull the wires out of the Anderson connector, use pliers to remove the tab things, and re-crimp, solder, and heat-shrink tube them onto longer and more flexible 4 AWG wire. We never have problems with them after this.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 31-01-2005, 11:07
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
This, and the one above, is the best method. However there are crimping blocks that can be used, just make sure you buy one that can handle two #6 cables. Split bolt connectors such as McMaster Carr #6921K57 is an example. Wrap it well with insulating tape!
Andy Brockway
Team 716, The Who'sCTEKS
Unread 31-01-2005, 13:32
AKA: Mr. Lim
Rookie Year: 1998
Thanks all!
Appreciate the solution(s)!
Unread 31-01-2005, 19:45
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
I know this isn't probably the best method (the 4awg method sounds a lot better in fact...) but in a spot last year we were getting the bot ready for a presentation to get a sponsor, and it turned out that a splice in one of the 6awg, was just 2 battery lugs bolted together, and one of the lugs was coming loose.
Well I decided that soldering it was probably the best solution right then. So I pulled the battery lugs off (rather easily I might add :-/ ) spread the wire out a bit, meshed the two pieces together, and soldered the joint with a propane torch (a full sized one not a mini one, big ol 12" flame on that sucker)
For last minute work it came out nice, I would be more confident in that than the battery lugs. For some reason I have an immense disliking for non-soldered joints. Maybe it is just all the hobby electronics I do...
Unread 31-01-2005, 23:08
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
just as long as you know how to solder (ex) dont use a puny 20W iron for 6 guage), it might not be as efficient or flexible but it will be solid
Unread 01-02-2005, 02:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We bought identical connectors to the ones in the kit and are soldering in 6 ga welding cable (super flexible and finely stranded) It was a pain to find (in red). We would have gone to 4 ga (and bigger powerpoles) but the 50 amp SB powerpoles (which we are required to use) only support contacts for up to 6 ga, so high quality 6 ga it is.
Why the smaller wire gauge? sanddrag Electrical 3 09-01-2005 11:53
10 gauge wire getting way hot dmellich Electrical 7 13-07-2004 10:03
Cutting wire on backup battery MikeDubreuil Electrical 4 23-02-2004 18:55
Wire Gauge Question Neghman Electrical 1 14-02-2004 19:56
Line sensor wire gauge questions Dinush Electrical 6 13-02-2004 18:41
