Go to Post ...when you see someone post about something they don’t like, please don’t post another “I’m sick of all this whining” type of post. If you disagree with them, try to offer an intelligent argument back. - Phil 33 [more]
Unread 04-02-2005, 04:18
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Low-Rider Robots
Originally Posted by SteveO
Anybody have an anti-tip mechanism We are going to try and use the accelerometer to automatically deploy "wheelie bars" if we are tipping a certain angle. We want to use probably pretty big pistons for this though and were heavy as it is
Yeah, our arm. Actually, it really depends on what drivetrain we want to pick (yes, I know its week 4, apparently we're building 3 different drives...). But if it's the kit bot, we have an anti tip mechanism which is essentially a set of outriggers powered by the window and van door motors.
And, about 2" of clearance -- it can be reduced though.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 04-02-2005, 13:41
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
in 2003 our robot had wheelie bars that were spring loaded so when the bot started to move the wheels pulled a string that pulled a pin to release the bars, it was light weight easy to make and replace. And it saved our bot from tipping more times then i can count.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 31-01-2005, 15:31
Cyberguy34000's Avatar
Cyberguy34000 Cyberguy34000 is offline
Scout-Master
AKA: Chris
FRC #0662 (Rocky Mountain Robotics)
Team Role: Scout
Cyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond reputeCyberguy34000 has a reputation beyond repute
Send a message via AIM to Cyberguy34000
Team 662's bot can now be classified as a "low rider". As you can see in the pic, it's barely off of the ground, we're probably going to put larger wheels on, just because the slightest bump in the carpet could beach the thing. But even after we raise it a bit, it'll still be pretty low to the ground.
In a game like this year's tipping is going to be a serious issue, so the lower the center of gravity, the less vulnerable you are.
I love deadlines, I love the wooshing sound they make as they fly by. - Douglas Adams
They who would give up an essential liberty for temporary security, deserve neither liberty or security. - Benjamin Franklin
Unread 31-01-2005, 15:35
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
we have enough clearance so we can drive over the base of the goals
Unread 31-01-2005, 15:37
Kyle's Avatar
AKA: Kyle Rice
FRC #0365 (MOE)
I was just wondering, is there a difference with ground Clarence when using wheels or treads? I have seen some bots that use treads with really low ground Clarence and some with high ground clearance.
Facebook
Unread 31-01-2005, 19:04
jrocket567 jrocket567 is offline
FRC #0617
Team Role: Mechanical
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
ground clearance is soley determined by the designer... tracks can be high and low, as well as wheels.. jst think of how you can take the same car and either jack it up a foot or so, or drop it down on the ground.. same principle, just that the robot is designed to do that in the beginning, and you dont have to take a torch to the springs..
j
Unread 31-01-2005, 21:14
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Team Role: Coach
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
ours is variable and the lowest i believe is 3/16.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 31-01-2005, 23:15
Gdeaver Gdeaver is online now
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
There is a time at the end of the game when a certain clearance is needed. If your paired with 2 other low riders, your aliance is going to have a problem.
Unread 31-01-2005, 23:18
Kyle's Avatar
AKA: Kyle Rice
FRC #0365 (MOE)
not unless there is a part on the robot to lift the low rider up..
Facebook
Unread 01-02-2005, 02:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I believe our ground clearance is around an inch. We would go either a little lower or a little higher (to drive in goals) but the ground clearance is dictated by our wheel size and frame design which is dictated by our gearbox output speed. We did some real world tests and we feel that on a flat playing field, the CG does not have to be quite as low as we thought to remain stable. So, an inch it is.
Unread 01-02-2005, 21:59
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
We have about 1.5" to 2" inches of ground clearance. Just enough to get over the goal bases. We're not sure if we'll need that clearence but i think its better safe than sorry. Of course for pushing you'll be pushing against something with a ground clearence of .25 or higher depending on how hard you push.
Team Website
Unread 04-02-2005, 23:21
cadman2k5 cadman2k5 is offline
AKA: steve lami
#0637 (Horsepower)
Team Role: Student
cadman2k5 is on a distinguished road
Send a message via AIM to cadman2k5
yea Team 637 knows what it feels like to flip... NOT FUN. were goin low too.. not a quarter inch... but low.
http://www.njfirst.org/galleries.htm
check out the upside down Marotta logo pic
Unread 04-02-2005, 23:32
Iain McLeod's Avatar
Iain McLeod Iain McLeod is offline
#0358 (Robotic Eagles)
Team Role: Scout
Iain McLeod is a glorious beacon of lightIain McLeod is a glorious beacon of lightIain McLeod is a glorious beacon of lightIain McLeod is a glorious beacon of lightIain McLeod is a glorious beacon of light
358 used to be .25'' but now we're about an inch.
I was really worried about flipping and crushing tetras this year too... everyone tells me that i'm exaggerating the danger, but i still vividly remember riding up onto balls many many times both last year and three years ago.
"The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at or repair." -Douglas Adams
Driving Robots under/into the Goals ... allowed? erniep Rules/Strategy 8 11-01-2005 22:32
Robots doing origami! RoboMom Math and Science 4 24-10-2004 19:42
Robots Doing the Dirty Work! Brandon Martus Announcements 2 23-06-2004 12:31
Robots compete in first match (FitN) Clark Gilbert FIRST In the News... 0 24-03-2004 18:11
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
