Go to Post Guys guys, what a coincidence! I INFACT <3 ROBOTS TOO! - Kusha [more]
Unread 31-01-2005, 23:47
Addy's Avatar
Addy Addy is offline
FRC #0097
Addy is an unknown quantity at this point
Problems in simulator mode
I am very new to programming, so I may be missing something stupid...
We added a simple bit of autonomous code into user_routines_fast.c, and wanted to see what was happening to the values of our variables without actually putting into the RC (as we can't really get to the robot as often as we'd like - still being worked on quite a bit! ), so we used the simulator mode explained in section 6.5 of the 2004 Programming Reference Guide (from IFI). We followed all the steps, built it, then ran it, and got this in the Output window (under the MPLAB SIM tab):
Six lines of "UART-W0006: Receive file has no data or failed to attach when UART receive mode enabled."
Then one line of "CORE-E0001: Stack overflow error occurred at 0x004836"
What does this mean we are doing wrong? (and how can we fix it?)
Thanks a lot!
Addy.
Unread 01-02-2005, 12:29
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Problems in simulator mode
It looks like you are running the Default Code v2.4, so you should have seen:
Code:
UART-W0006: Receive file has no data or failed to attach when UART receive mode Enabled.
The most likely culprit is a missing _SIMULATOR compiler flag.
Double check in MPLAB
Project -> Build Options... -> Project
The MPLAB C18 tab.
_SIMULATOR should be listed under Macro Definitions
If it isn't, make sure the "Use Alternate Settings" box at the bottom is NOT clicked, then add the compiler flag by clicking on "Add..." by the Macro Definitions box and typing _SIMULATOR in the pop-up that appears.
Re-build everything, then try running the debugger again.
Unread 01-02-2005, 12:36
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
After you are through simulating, turn the flag OFF and recompile (build all) before you program your robot.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
