Go to Post Chances are it's an electrical or mechanical problem... - mechanicalbrain [more]
Unread 01-02-2005, 19:27
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
pic: 226 Off-Season Gearbox
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
Unread 01-02-2005, 19:29
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: pic: 226 Off-Season Gearbox
Seems like the first I ask of question of any picture disussion is "how much does it weigh?" Also, what is the thickness on those plates. Did you waterjet the bearing holes, or were they machined? Also, what are the output speeds?
LivingDeadMan's Avatar
LivingDeadMan LivingDeadMan is offline
AKA: Bob
#0555 (555)
Team Role: Mechanical
LivingDeadMan is an unknown quantity at this point
Send a message via AIM to LivingDeadMan
Looks good!
Unread 01-02-2005, 19:41
Rookie Year: 1999
How much does it weigh? Not really sure, it is waterjet cut from 1/4" 6061. The bearing holes were reamed after the waterjet to get them to the final tolerance, however the real version is laser cut an right on the money. The intent with the box above was to have the capability of the drill spinning the same direction in both gearbox (One side had an additional reversing gear as you can see from the bearing cutouts) then through the shifter and into a hex bore. The drive module then has a telescoping hex shaft that slides in. The encoder is mounted in the gearbox and picks up the output of the 60tooth gear on the output. A servo lays flat above the CIM motor and manipulates the paddle shift. The final version is lighter in the plates with the same weight in the gears (which are all lightened) Pics next week.
Unread 01-02-2005, 20:03
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
Nice work, are you sponsored by a laser cutting company?? Seems like you guys get a lot of that stuff done...
Unread 01-02-2005, 20:53
Rookie Year: 1999
Actually we are sponsored by GM Conveyors, Controls, Robotics, and Welding but we have lotsa labs with lotsa neat equipment.
As for the prototype robot above it was all done at a local waterjet company - Copland Gibson at their full cost which was right around $400 for the first plate and about $250 for each additional (1st plate has a CAD fee) Water-jet cutting is an extremely good deal for FIRST teams, we couldn't have done it with a CNC mill it would have been too expensive.
As for getting lots of parts made, well that's just part of the business situation and rules we have to live by.
pic: 2005 226 Chassis Render Matt Reiland Extra Discussion 12 02-02-2005 00:56
pic: Team 716 Gearbox Andy Brockway Extra Discussion 12 01-02-2005 09:18
A report on off season competitions Ken Leung Off-Season Events 2 17-10-2003 13:30
Highlights of the season... Alexander McGee General Forum 25 26-06-2003 03:13
