Go to Post It goes to show how a FIRST team is not one person but a complex codependence of people who are all striving to meet the same goal. - Bill_Hancoc [more]
Unread 01-02-2005, 20:34
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Speed controllers won't communicate w/robot controller
I'm pretty sure I saw someone with the same problem a while back on the forums, but after a good half-hour of searching I couldn't find it - so please excuse me if this has already been solved. I hooked up our robot controller to the speed controllers with the kit-provided data cables, and they blink yellow exactly as if they were not plugged in. I can take the same cable and move it to last year's robot controller, and immediately the light goes solid as it should. Why would the new robot controller not provide the poor Victors with the proper signal? Battery and backup battery, of course, plugged in (although I believe the backup battery is not necessary) and to the best of my knowledge everything is plugged in just fine. I even tried reversing the connectors, with no effect. I certainly hope this isn't a hardware problem...
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
speed controllers & circuit breakers deuceswild Electrical 2 15-01-2003 14:46
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
