Go to Post However, I do expect something truthful to come out of some of Dave's posts. - Karibou [more]
Unread 02-02-2005, 00:57
JoelP JoelP is offline
whats the P for? Pazhayampallil
FRC #1155 (Bronx Science Sciborgs)
Team Role: Leadership
JoelP is a jewel in the roughJoelP is a jewel in the roughJoelP is a jewel in the rough
Send a message via AIM to JoelP
Custom LED outputs
hi, rookie programmer here
In the IFI operator interface manual, it says that port 1 and port 3 have robot feedback LED pins so you can display feedback on a custom control box. I would like to do that on a custom box along with some switches, however, it also says that these feedback LED pins just copy the LEDs on the Operator Interface. This seems a little pointless to show the same information in 2 places. I would like LEDs on the control box to display a different set of informations, sooo
in short, is there a way to map out the pins on the ports to control different feedback LEDs that you could add to the code? eg. Relay3_red, Relay3_green?
btw, i'm not sure if this is against the rules or anything
Unread 02-02-2005, 01:20
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: Custom LED outputs
Originally Posted by JoelP
I would like LEDs on the control box to display a different set of informations, sooo in short, is there a way to map out the pins on the ports to control different feedback LEDs that you could add to the code?
No, you're limited to the outputs that are provided, which do mirror the LEDs on the OI. It is useful if you want to arrange them differently or use different colors, etc.
If you need more feedback than what is provided by those LEDs, you can look into using a laptop or handheld device to display data from the dashboard port on the OI. If you're interested in that then search around here for the word 'dashboard' and you should find lots and lots of good information.
Making a beacon indicator LED burn its brightest without burning out DanL Electrical 7 26-01-2004 08:05
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
