Go to Post You could mount a small Black Hole on the top of your bot, and park it in front of the center goal - that would work...just keep your human player away from the event horizon. - KenWittlief [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 02-02-2005, 23:08
Ein's Avatar
Ein Ein is offline
I Know John Neun
FRC #0020 (The Rocketeers)
Ein will become famous soon enough
Constraining Gears in Inventor 8
I know how to ser a rotational constraint with the proper ratio between two gears, but is it possible to constrain the teeth as well? If you just set a ratio, the teeth tend to unmesh after a while. I checked around and the answer seems to be no, but sometimes you get lucky. The gears are accurately drawn as I got them from Boston Gear.
UTC 2005 GM Industrial Design Award
UTC 2005 Finalist w/ 173 & 230
UTC 2005 Top Seeded team
[ECDU]
Unread 03-02-2005, 19:58
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Constraining Gears in Inventor 8
Making proper gears in anything is EXTREEMLY dificult. Many will just make a close approximation of the gears. Usually, it isn't necessary, nor is it recomended, to constrain gears pefectly. I don't know what gears you are using, nor do I no if they would even be visible normally. I have seen the inventor for the kit transmistion and it has incredible detail, but I wouldn't even try to have all of those gears and everything move correctly. The reason is that (according to a college student that did incredible Inventor stuff), gears have very more complex shapes than may give them credit for. The gears must be made to exact specifications in Inventor to even possibly work correctly.
Don't worry though. If they get the proper speed ratio out of them, chances are that the gear teeth are too small to be seen when you drive the constraint. However, if someone does know how to do this correctly, I would love to know.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 03-02-2005, 20:11
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
I've tried. It's not worth it. just line them up so they look like they are meshing and then make the rotational constraint. It'll keep them lined up correct for a while.
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
request for info on gearbox gears jskene Technical Discussion 0 08-01-2005 18:07
Looking for gears from BostonGear in Inventor.. geo Inventor 6 05-08-2004 10:07
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
Gears in Inventor Joshua May Inventor 12 01-07-2004 23:32
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
