Go to Post Adversity should be seen as a challenge and not as an obstacle. :D - waialua359 [more]
Unread 03-02-2005, 09:15
Swampcoder2 Swampcoder2 is offline
#0179 (Children of the Swamp)
Swampcoder2 is on a distinguished road
Exclamation *NOT THE BACKUP BATTERY * Automatic Power
Over the past week, we've been test driving our chassis. The electronics module is pre-wired and self-contained. The battery is mounted to the chassis. We added the module to the chassis, connected the motor wires through a terminal strip and connected the battery via the supplied QD connectors. The 120A circuit breaker, fuse panel and electronics are wired as outlined in the wiring diagram.
The cool thing is, we drove around fine, set the chassis up on a table to check a few things and while we're talking and pointing out something, I feel air blowing on my arm... Confused, I look over to see the Victor fans are running, their LED's are on... I continue looking around the module and notice the spikes are on, the RC is running, the fuse panel LED is on, the whole electrical system is running - I check the 120A breaker and it's OFF!!!?? I quickly try to trip the breaker but nothing happens, I cycled the breaker and it stayed on... finally, I disconnected the battery and the power turned off.
Our robot is possessed!! I plugged the battery back up a little later and the breaker functioned as normal. Later that day or the next day, the same thing happened. We've been running without incident the past few days.
Has anyone experienced this? I think there is an evil gremlin in our breaker.
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
Using ground stem for power distribution steven114 Electrical 9 23-02-2004 11:40
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
