Go to Post Sorry, solenoids don't speak English. You can talk at them, but they won't answer except maybe to sigh... - Mark McLeod [more]
Unread 03-02-2005, 18:03
Jatheon4316's Avatar
Jatheon4316 Jatheon4316 is offline
AKA: Jason
None #0500
Jatheon4316 can only hope to improve
Send a message via AIM to Jatheon4316
Post Joystick Inputs
Hello fellow programmers!
Would someone please tell me what the inputs are for the the 2004 and or 2005 FIRST joysticks? Including x and y axis, trigger, top button/HAT (depending on year) etc...
Thanks!
Unread 03-02-2005, 18:16
Bleric's Avatar
Bleric Bleric is offline
#0624 (CRyptonite)
Bleric is on a distinguished road
Send a message via AIM to Bleric Send a message via MSN to Bleric
Re: Joystick Inputs
*cough* documentation *cough*
Anyway, the variables you will be using are
p1_y
p2_y
p3_y
p4_y
p1_x
p2_x
p3_x
p4_x
p# refers to the port you're plugging the joystick into. x / y refer to the x and y axis. Values range from 0 - 255.
For example, if you're looking at the joystick in port one, and it is held in the center, p1_y is 127 and p1_x is 127.
p1_sw_trig
p1_sw_top
p3_sw_trig
p3_sw_top
p2_sw_trig
p2_sw_top
p4_sw_trig
p4_sw_top
These refer to the trigger and top buttons. (If you're using the white kit joysticks, I think the "top" button is actually on the side) They're set to 1 if the button is being pushed, and 0 if it isn't.
I'm pretty sure the "hat" button isn't even wired. So, you can't use it unless you take your joystick apart and wire it up yourself. (I may be wrong on this, though)
Also, I would read all the documentation I could find if I were you. Innovation first has a programming guide which I found very useful, and should answer most of your questions.
useful links
programming guide
Unread 03-02-2005, 19:00
AKA: Jason
None #0500
Re: Joystick Inputs
Thanks...I must've missed that in the documentation *rubs eyes wearily*...
Unread 03-02-2005, 19:28
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
Re: Joystick Inputs
all the definitions are in ifi_aliases.h . you shouldnt need to change anything there, but that will give you a good idea of the variables. Btw the p_wheel definitions is for the hat. Its wierd how it works, but i messed around with it and it does work
Harker Robotics:1072
http://www.harker-robotics.org
Unread 03-02-2005, 23:13
AKA: Jason
None #0500
Re: Joystick Inputs
Ok, here's another question...
I know that the joystick's y axis value is highest (ideally 254) when it's full forward and lowest (ideally 0) when it's full backward.
However, what about the x_axis? Is highest (ideally 254) at the left or the right? And is the lowest (ideally 0) at the right or the left.
y=254?
full forward
x=? full left ----+---- full right x=?
full backward
y=254?
Unread 04-02-2005, 06:38
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
Re: Joystick Inputs
I can't remember it at the moment, but you can easily check it with printf, for example:
printf("Port1 Y %3d, X %3d, Fire %d, Top %d, lm %d, rm%d\n, ,%d , %f",(int)p1_y,(int)p1_x,(int)p1_sw_trig,(int)p1_sw _top,lm,255-rm,5/3, 5/3 );
Unread 04-02-2005, 06:42
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Re: Joystick Inputs
y=254?
full forward
full backward
y=254?
Yes, it is 0 and 254, if I recall correctly.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 04-02-2005, 07:35
AKA: Jason
None #0500
Re: Joystick Inputs
0=full left (ideally)
-to-
254=full right (ideally)
Right?
Sorry to bug ya'll. But I won't see our bot and joysticks again till Saturday (or would've used a printf statement to find them)...thanks!
Unread 04-02-2005, 16:08
Anton's Avatar
Anton Povzner
#1581 (Element)
Re: Joystick Inputs
I remember being really surprised to see that the algorithm I developed wouldn't wprk just because x- axis had 255 as the left value, not the right one as I expected, but soon I realised that to invert it I just had to add a line of code p1_x=255-p1_x;
What I'm trying to tell is that even if you don't know the correct axes values you don't need to worry, you can easily map them as you wish-you can even make them -127 to 128, if you think that it's worth the effort. Personally, I htink it would be nice, but I already wrote half my brogramm using the default values, so there's no point giving myself more work than needed. But if you are just beginning the joysticks, I think it's a good thing to do.
Unread 04-02-2005, 16:53
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Re: Joystick Inputs
Would someone please tell me what the inputs are for the the 2004 and or 2005 FIRST joysticks? Including ... top button/HAT
This thread from last year covered the"top button/HAT". I don't know if IFI has fixed the "feature" whereby any deflection in the up direction are indistinguishable.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 04-02-2005, 17:06
Darkelement's Avatar
Darkelement Darkelement is offline
Team 241 Lead Programmer
AKA: JC Morgan
FRC #0241 (The Astros)
Rookie Year: 2000
Darkelement is an unknown quantity at this point
Re: Joystick Inputs
I thought that the joystick range was 0 to 255. That's what I have been inputting and I haven't had any problems.
Unread 06-02-2005, 12:01
The yellowdart's Avatar
The yellowdart The yellowdart is offline
FRC #1506 (Metal Muscle)
The yellowdart has a little shameless behaviour in the past
Re: Joystick Inputs
full ahead should be 254
127 is neutral.....
full reverse should be 0
full right should be 254
and full left should be 0
again with neutral being 127
hope that helps
Unread 06-02-2005, 17:25
Workaphobia Workaphobia is offline
AKA: Jon
FRC #1546 (Chaos Inc.)
Workaphobia will become famous soon enough
Re: Joystick Inputs
The hobby controller I used for my team's EDUbot fell short of the full analog range by 20-40, robbing us of some control resolution. I don't think the joysticks in the FRC kit had this problem, but you can always test the range, and which side is which, by outputting the contents of p1_y (and the others) to User_Mode_byte and switching to user mode in your operator interface.
Problems hooking up a joystick to edubot Salik Syed Programming 2 24-03-2004 23:56
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
