Go to Post "You know, a robotics regional is the only place where you can walk in and see two people in chicken suits and not be confused." - Herodotus [more]
Unread 04-02-2005, 14:50
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Team update 8 now out.
Team update #8 is now out and available at http://www.usfirst.org/robotics/2005/tmup.htm
some main points are
there will be practice Field materials at the events but it is up to non FIRST people to set up and man them
G14 is modified to add a 10 point penalty for teams touching the auto loader before entering the loading zone.
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 06-02-2005, 20:31
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: Team update 8 now out.
Yes....so the question I have is, what is the definition of being "in the loading zone"?
Does having an arm extending over the yellow triangle count....or does a robot hAVE TO BE "touching" the triangle?
Does the manual describe that being "in the loading zone" means?
I suppose it does because there are so many rules about not interfering witha robot when it is in the loading zone.
Can anyone point me at an answer to when one is in the loading zone? (sorry if this is a dumb question....I might have missed the obvious definition in the rules)
-Quentin
Live free or die....
Unread 06-02-2005, 20:41
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
This is an important question and I think somewhere in the FIRST Q & A early on they implied that a portion of the robot had to be over the triangle base. They also implied that one should make it obvious that their robot was "In the Zone."
This is obviously a safety concern for the volunteers who will be reloading. It would be nasty to see someone get a fracture or bloody nose while reloading the station.
I should quote my references but I have grade reports to get out tomorrrow
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 06-02-2005, 21:58
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
-Quentin
Here is your reference:
Q&A #978:
"ID: 978 Section: 4.3.3 Status: Answered Date Answered: 1/11/2005
Q: Regarding <G17>: What are the parameters for being "in" a loading zone? (i.e., must some part of the robot be touching the yellow triangle, et cetera)
A: There are no yellow triangles in the loading zones. The robot base and / or drive train must be touching the loading zone. The intent of this rule is that you must be in the loading zone. By making it blatantly obvious that you are in the loading zone, you will draw far less attention from the referees. "
- from B B frank
Unread 07-02-2005, 09:33
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
Rookie Year: 1997
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
What am I missing here? The loading zone is NOT clearly identified, yet you might get penalized if you aren't in it while attempting to load a tetra.
What does blatantly obvious mean, when the loading zone is not clearly identified? It is clear to me that the triangles don't define the loading zone, but what does? Wouldn't it be easier on everyone if the Loading zone were clearly outlined using white duct tape. Please indicate the area that the robot base or drive train must be in before the robot can touch an auto loader, otherwise it comes down to a judgement call by the referee as to the location of the robots wheels at the moment the loader is touched. In some cases (robots with very long arms) it will be obvious. On the shorter armed robots it won't be as easy to tell, because the referee cannot be looking at 2 things at the same time.
Unread 07-02-2005, 09:51
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Rookie Year: 1996
dlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond reputedlavery has a reputation beyond repute
Please read Section 4 of the manual. In particular look at the definitions section, and the entry for "Loading Zone." Please refer to the artwork on the first page of Section 4, with the big arrows that say "Loading Zones" by them.
The loading zones are quite clearly identified. Question #978 makes it clear what the referees will be looking for when they check to see if you are "in" the loading zone.
-dave
"I know what you're thinking, punk," hissed Wordy Harry to his new editor, "you're thinking, 'Did he use six superfluous adjectives or only five?' - and to tell the truth, I forgot myself in all this excitement; but being as this is English, the most powerful language in the world, whose subtle nuances will blow your head clean off, you've got to ask yourself one question: 'Do I feel loquacious?' - well do you, punk?"
- Stuart Vasepuru, 2006 Bulwer-Lytton Fiction Contest
My OTHER CAR is still on Mars!!!
Unread 07-02-2005, 10:02
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What am I missing here? The loading zone is NOT clearly identified, yet you might get penalized if you aren't in it while attempting to load a tetra...
You're missing Section 4 of the manual, apparently. The loading zone is clearly defined as follows:
LOADING ZONE – The triangular colored area on the floor at the sides of the field where robots may receive and/or retrieve TETRAS that are introduced into the game.
Unread 07-02-2005, 10:28
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
The blue (or red) triangles DO define the loading zone. The manual states that they are triangles with each side 36" long. I have taken the intent of the rule to be this (purely my opinion):
1. Don't have your robot positioned in front of a goal and reach over and grab a tetra from the loading station.
2. Don't grab the tetra with a long arm before your drive base gets to the triangle.
3. If your drive base is covering some portion of the triangle, you will be considered "in the loading zone"
Now, I know these are assumptions I am making, but I think they are logical. Will a ref be laying on the ground to see if my wheels are touching the triangle on the floor or will a ref be looking for my drive base to cover the triangle? I don't know, but I am guessing that it will be the latter.
-Paul
Unread 07-02-2005, 10:59
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Ok, I just want to be very clear on this. Is the loading zone three dimensional, or is it two dimensional? I think the problem here is their use of the word "in" rather than the word "on". "In" kind of implies a three dimensional area, but as I am reading things it is actually two dimensional.
Unread 07-02-2005, 16:10
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Every indication that I've gotten is that it is two dimensional.
Unread 07-02-2005, 16:14
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
It is two dimensional.
The same 'in' is used when referring to an end zone in football, but we know it's two dimensional.
"Did he get in the end zone?"
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 07-02-2005, 16:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
The end zone is three dimensional though. If the football crosses the plane of the goal line, it's "in", regardless of whether the ball or the player touches the ground.
But the loading zones are 2D, it seems
2001-2004: Team 100
2006-Present: Team 254
Unread 08-02-2005, 07:43
volunteer helper
FRC #6099 (Knights)
Rookie Year: 1997
Thankyou Dave for clearing up my concern. I have read section 4 and I missed the color of the triangle was red or blue NOT yellow. With the response written "There are no yellow triangles in the loading zones", I assumed the question author had stated the color correctly and that I missed something. My fault - it's clear now that the zones are clearly marked (they are NOT yellow).
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
2005 Team Update #7 posted Goobergunch General Forum 0 01-02-2005 16:53
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Renovating a Team av11d Team Organization 2 18-04-2004 20:06
Disqualifications archiver 1999 13 23-06-2002 21:53
