um.. I'm sort of new at this robotics thing and was wondering how to cut holes and pieces from objects in 3ds max. Please help!
![]() Last edited by stinger : 05-02-2005 at 17:51. Reason: found out about curving corners |
Re: cutting pieces of objects in 3ds max
There are a few different ways -- I'll just list a couple.
ok... but now i cant figure out how to convert it into an "editable poly"
... so how do I? |
You can right click on it, and go to "convert".
However, i would look into using the compound object system: boolean objects. Basically, you make two objects. One of them is the part, the second is the area that you want removed from the part. Use the help file and tutorials to learn more about them. It's a great beginner's technique. IM me if you need help. -axe |
Thanks a lot
uuummm.... exactly how do i close this thread???
| Importing Inventor Into 3ds max? | Jeremiah Johnson | 3D Animation and Competition | 8 | 31-01-2005 21:30 |
| **FIRST EMAIL**/Gear Up with Live Inventor and 3ds max Trainings! | Billfred | FIRST E-Mail Blast Archive | 0 | 22-12-2004 16:30 |
| Another 3ds max "Key" | Jack | 3D Animation and Competition | 7 | 09-05-2002 21:19 |
| Text effects in 3DS Max... | Ranma | 3D Animation and Competition | 6 | 28-02-2002 21:56 |
| Autodesk Inventor -> 3ds Max (File Format) | Adrian Wong | Inventor | 1 | 22-01-2002 23:06 |
