Autonomous Camera Integration
Hey all,
My team is having quite a problem attemping to integrate the current camera code (2-26) into our default code for autonomous. We're hitting all sorts of problems. Can anyone PLEASE share their implementation so we have something to go off of? We're totally stuck here! Thanks!! -Greg, 384 |
Re: Autonomous Camera Integration
Here's my two implementations:
Code:
int cmd_point_at_color(void)
#if _USE_CMU_CAMERA
static int state = START;
static int color;
static long int tolerance;
static long int time_out;
int rc = DONE;
long int heading_error;
switch (state)
case START:
color = PARAM1;
time_out = robot_time + PARAM2;
tolerance = MRAD2SERVO(PARAM3);
camera_find_color(color);
printf("Looking for color %d\r", color);
state = TURNING;
rc = WORKING;
break;
case IN_PROGRESS:
case TURNING:
case STOPPED:
case LOST:
if (cam.x == 0) //Not found!
state = LOST;
break;
heading_error = (signed int)cam.pan_servo - 128; //BOT: center of X on cam
// Whether we are turning or stopped we want to always check heading
if (heading_error < -tolerance)
// Turn Left
set_vel(LEFT, TURN_SPEED);
set_vel(RIGHT, -TURN_SPEED);
state = TURNING;
else if (heading_error > tolerance)
// Turn Right
set_vel(LEFT, -TURN_SPEED);
set_vel(RIGHT, TURN_SPEED);
state = TURNING;
else
if (state == TURNING)
set_pid_stop(LEFT);
set_pid_stop(RIGHT);
state = STOPPED;
else
// We are stopped, so maintain postion
set_pos(LEFT, 0);
set_pos(RIGHT, 0);
if (robot_time > time_out)
state = COMPLETE;
rc = WORKING;
break;
case COMPLETE:
state = START;
camera_stop();
rc = DONE;
break;
return rc;
#else
printf("POINT_AT_COLOR: Camera is not being used!\r");
return DONE;
#endif
int cmd_goto_color(void)
#if _USE_CMU_CAMERA
static int color;
int rc = DONE;
switch (state)
case START:
color = PARAM1;
printf("Going to color %d\r", color);
state = IN_PROGRESS;
rc = WORKING;
break;
case IN_PROGRESS:
case TURNING:
case STOPPED:
case LOST:
state = LOST;
break;
// Turn Left
set_vel(LEFT, TURN_SPEED * abs(heading_error)); //Psuedo PID (more of a PD)
set_vel(RIGHT, DRIVE_SPEED);
state = TURNING;
// Turn Right
set_vel(LEFT, DRIVE_SPEED);
set_vel(RIGHT, TURN_SPEED * abs(heading_error)); //Psuedo PID (more of a PD)
state = TURNING;
else
// We are right on
state = COMPLETE;
rc = WORKING;
break;
case COMPLETE:
/* set_pos(LEFT, counts);
set_pos(RIGHT, counts);*/
camera_stop();
state = START;
rc = DONE;
break;
return rc;
#else
printf("GOTO_COLOR: Camera is not being used!\r");
return DONE;
#endif
Code:
int cmd_camera_stop(void)
#if _USE_CMU_CAMERA
printf("Stopping camera\r");
camera_stop();
return DONE;
#else
printf("CAMERA_STOP: Camera is not being used!\r");
return DONE;
#endif
int cmd_track_color(void)
#if _USE_CMU_CAMERA
int color = 0;
color = PARAM1;
printf("Tracking color %d\r", color);
return DONE;
#else
printf("TRACK_COLOR: Camera is not being used!\r");
return DONE;
#endif
int cmd_turn_to_color(void)
#if _USE_CMU_CAMERA
int rc = DONE;
switch (state)
case START:
time_out = robot_time + PARAM1;
tolerance = MRAD2SERVO(PARAM2);
printf("Turning towards tracked color.\r");
state = TURNING;
rc = WORKING;
break;
case IN_PROGRESS:
case TURNING:
case STOPPED:
case LOST:
state = LOST;
break;
// Turn Left
state = TURNING;
// Turn Right
state = TURNING;
else
set_pid_stop(LEFT);
state = STOPPED;
else
set_pos(LEFT, 0);
set_pos(RIGHT, 0);
state = COMPLETE;
rc = WORKING;
break;
case COMPLETE:
state = START;
rc = DONE;
break;
return rc;
#else
printf("TURN_TO_COLOR: Camera is not being used!\r");
return DONE;
#endif
int cmd_drive_to_color(void)
#if _USE_CMU_CAMERA
int rc = DONE;
switch (state)
case START:
printf("Driving towards tracked color\r");
rc = WORKING;
break;
case IN_PROGRESS:
case TURNING:
case STOPPED:
case LOST:
state = LOST;
break;
// Turn Left
state = TURNING;
// Turn Right
state = TURNING;
else
// We are right on
state = COMPLETE;
rc = WORKING;
break;
case COMPLETE:
state = START;
rc = DONE;
break;
return rc;
#else
printf("DRIVE_TO_COLOR: Camera is not being used!\r");
return DONE;
#endif
Thank you!
We're getting all sorts of errors with what we are trying to do, we'll take a look at yours to try to figure out our own problems x_x Thanks again -greg |
| Scripting Setup and the Camera + Serial Port Drivers | CJO | Programming | 22 | 11-01-2006 17:42 |
| Autonomous With Camera | schenkin | Programming | 20 | 16-02-2005 23:52 |
| CMUCam2 Camera Code - Are important parts commented out? | Mr. Lim | Programming | 4 | 14-01-2005 12:11 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
