Go to Post Gracious professionalism dictates that if you come to play, I must help you. - Al Skierkiewicz [more]
Unread 05-02-2005, 18:23
Der Sichelmann's Avatar
Der Sichelmann Der Sichelmann is offline
Professional Team Member
#0358 (Eagles)
Team Role: Student
Der Sichelmann is an unknown quantity at this point
Batteries
Our team did a 16 amp battery test. A 2005 battery went down to 10 volts in 21 minutes. The other batteries we tested took at least 40 minutes. One of our 2005 batteries is of poor quality.
Unread 05-02-2005, 18:26
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: Batteries
Were you just stating this for everyone to know or did you have questions about what was happening?
Unread 05-02-2005, 18:33
#0358 (Eagles)
Team Role: Student
Re: Batteries
Just an observation. It might be a good idea to test batteries. This started as a comparison between 2004 batteris and 2005 ones and we found a bad 2005.
Unread 05-02-2005, 18:29
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Re: Batteries
I'm a little confused. That does not look like an Exide-18-12 official FIRST approved (re: only Brand and Model number battery you can use in 2005) in your picture.
Explanation?
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 05-02-2005, 18:32
#0358 (Eagles)
Team Role: Student
Re: Batteries
Explanation?
That is a practice battery we tested today. The Exide batteries were tested last night and are currently on charge.
Unread 05-02-2005, 18:34
Re: Batteries
That is a practice battery. The approved Exide batteries are currently charging.
Ok, gotcha.. lol I thought you were referring to the pic as "this is the one we tested".
Sorry about that.. Didn't mean anything by it. Forgive me?
Unread 05-02-2005, 18:35
#0358 (Eagles)
Team Role: Student
Re: Batteries
yea. Someone said to switch batteries but we took the pic anyway.
Unread 05-02-2005, 23:31
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: Batteries
If anyone is curious what we did to test them - we built a circuit that had a load on it and was connected to the battery (and two large muffin fans to cool it all off) then timed how long it took the battery to drop to 10v.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 05-02-2005, 23:36
Max Lobovsky's Avatar
Max Lobovsky Max Lobovsky is offline
Fold em oval!
FRC #1257 (Parallel Universe)
Max Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant futureMax Lobovsky has a brilliant future
Send a message via AIM to Max Lobovsky
Re: Batteries
It looks like you used some sort of large resistor. In that case, you were not drawing exactly 16 amps the whole time. Because you only measured down to 10V, it is probably close enough, but I just wanted to point it out.
Learn, edit, inspire: The FIRSTwiki.
Team 1257
2005 NYC Regional - 2nd seed, Xerox Creativity Award, Autodesk Visualization Award
2005 Chesapeake Regional - Engineering Inspiration Award
2004 Chesapeake Regional - Rookie Inspiration award
2004 NJ Regional - Team Spirit Award
Unread 05-02-2005, 23:38
Running Riot
AKA: Patrick Cloke
Re: Batteries
Yeah it was a resister, not sure what its rating was though. Why wouldn't it be pulling 16 amps all the time though?
And we actually timed it a little past 10v, but the only time amount we cared for was 10v.
[Edit: Hmm...I didn't really mean to make it sound "snappy", I just don't understand why it wouldn't do that.]
FIRSTsearch
Unread 05-02-2005, 23:50
Fold em oval!
Re: Batteries
V=IR. If V goes down, and R is constant, I must go down.
Team 1257
Unread 05-02-2005, 23:55
Running Riot
AKA: Patrick Cloke
Re: Batteries
Oh, that clears it up. Thanks.
FIRSTsearch
Unread 06-02-2005, 05:46
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Batteries
This is pretty unusual for batteries to be bad out of the box. Although I can't open the file (I will try from work tomorrow) it would appear that the battery might not have fully charged. This can occur when there is a high resistance connection to the charger. I would double check all electrical connections, charge it up and try it again.
It is interesting to note here that an 18 AH battery cannot supply 18 amps for one hour. The spec sheet lists the test parameters and the final test voltage vs. time but it should be noted that the battery changes output with temperature as well.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 06-02-2005, 19:47
Running Riot
AKA: Patrick Cloke
Re: Batteries
We're charging it up again and will check tomorrow night. It was definitly fully charged (left over night), I'm not sure about the connections though. I'll check it tomorrow before we test it.
FIRSTsearch
  #15   Spotlight this post!
Unread 17-02-2005, 03:45
eugenebrooks eugenebrooks is offline
AKA: Dr. Brooks
no team (WRRF)
eugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond reputeeugenebrooks has a reputation beyond repute
Re: Batteries
We finally got our current regulated capacity tester running, and have tested two ES-18 batteries from 2004, and the two EX-18 batteries that arrived in the KOP for 2005. Given a constant load current of 20 amps, and a cutoff voltage of 11 volts, the two 2004 batteries lasted 32 minutes, while the two 2005 batteries lasted 22 minutes.
The capacity of the EX-18 batteries does appear to be 50% lower.
If your robot will have high current draw you need to pay careful
attention to this issue...
Keeping batteries during shipping Andy Brockway Rules/Strategy 4 17-02-2005 17:37
# of Batteries at regional HPA_Robotics_13 Electrical 15 15-02-2005 23:18
EX18-12 Batteries in KOP Andy Brockway Electrical 3 14-01-2005 11:34
Batteries Exide 2005 Quanity Mike Martus Electrical 6 13-01-2005 19:44
HELP - We have no batteries!! Rick Gibbs Championship Event 3 24-04-2002 19:07
