Go to Post A very important thing that I learned is how to think, not what to think. - Anna B. [more]
Unread 06-02-2005, 01:08
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Sleeve on Fisher Price
What is the purpose of the thin metal "sleeve" on the fisher price motor? Should this be taken off if we use a heatsink?
Unread 06-02-2005, 01:59
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
Re: Sleeve on Fisher Price
It is a flux yoke (as Joe Johnson calls it), and provides an additional magnetic path between the field poles. It should not be removed unless you want to reduce the torque of the motor. Like the fan blades you broke earlier, it wouldn't be there if it weren't important.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 06-02-2005, 02:02
Team Role: Teacher
Originally Posted by ahecht
It is a flux yoke (as Joe Johnson calls it), and should not be removed unless you want to reduce the torque of the motor.
Could you explain this a little more? Yoru saying it alters the magnetic field?
Unread 06-02-2005, 02:09
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
http://www.chiefdelphi.com/forums/sh...8&postcount=27
See this post for an explanation. Basically, more metal means more magnetic field. Since F = q v B sin(theta), more magnetic field (B) means more force (F).
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 06-02-2005, 02:12
ahecht's Avatar
'Luzer'
AKA: Zan
I don't want to get too much into motor theory, as it's been a while since I've done this stuff, but basically the job of the yoke is to provide a path for the magnetic flux. As I remember it, having a steel path between the magnets instead of air increases the flux density, and therefore the efficiency of the motor (someone correct me if I've got this backwards or plain wrong). The more steel the better, up to a point when things become saturated.
Zan Hecht
Use of the fisher price motor ALONE Some Guy Motors 6 03-02-2005 08:55
Fisher Price Motor Into Drill Gearbox Chris Technical Discussion 11 21-04-2004 09:09
Fisher Price Brush Arching?? Andy4Hawks Motors 9 26-02-2004 07:24
Multiple Fisher Price Motors? authgeek1218 Motors 5 10-01-2003 10:48
New Fisher Price Motor - IMPORTANT Paul Copioli Motors 6 08-02-2002 13:35
