Go to Post Now the big question is, does Dave think this is pimp? - Mike Schroeder [more]
Unread 07-02-2005, 00:24
Grizzlie's Avatar
Grizzlie Grizzlie is offline
Grizzlie is an unknown quantity at this point
Post Solenoid control
I am trying to program the solenoids this year to wherewhen i hold the trigger it activates and when i let go it deactivates. Same as the reverse motion. I wrote this code to do this but it wont work. When i press the trigger the solonoid activates but when i let go it doesnt stop. And it WILL NOT go back when i press the rev button. heres the code i wrote :
Code:
 if (p3_sw_trig);
      relay3_fwd = 1;
if (!p3_sw_trig);
      relay3_fwd = 0;
if (p3_sw_top);
      relay3_rev = 1;
if (!p3_sw_trig);
      relay3_rev = 0;
It would be great if someone could explain to me what i did wrong here because i'm fairly new to the C language. But it would be even better if someone could post the exact code to make this work. Thank You for even taking your time to read this post. And also good luck this year!
"Act Quickly , Think Slowly" - Greek Proverb
2005 RadioShack® Innovation in Control Award! dez250 General Forum 10 10-03-2005 21:29
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
