Go to Post I want to use some of that mass-less rod in our robot - saves weight. - ebarker [more]
Unread 07-02-2005, 20:50
arbershametaj's Avatar
arbershametaj arbershametaj is offline
AKA: Arber
FRC #0369 (Nuts and Volts)
arbershametaj is an unknown quantity at this point
Send a message via AIM to arbershametaj Send a message via MSN to arbershametaj
what do u think we used this 4 :D
get back at me
Unread 07-02-2005, 21:47
UsmanB UsmanB is offline
Michigan Wolverine CO/2009
None #0123 (123 Cosmos)
UsmanB will become famous soon enough
Re: what do u think we used this 4 :D
do u mind croping the image a bit, its so big; its about 200% my screen size.
Unread 07-02-2005, 21:55
roboticsguy1988's Avatar
roboticsguy1988 roboticsguy1988 is offline
Larry Johnston
AKA: Larry Boy
FRC #1501 (Team THRUST)
Team Role: Electrical
roboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud ofroboticsguy1988 has much to be proud of
Send a message via ICQ to roboticsguy1988 Send a message via AIM to roboticsguy1988 Send a message via MSN to roboticsguy1988 Send a message via Yahoo to roboticsguy1988
WHOAH that is big, and my screen is set at 1280 X 1024.
Larry Johnston, Team THRUST, Team #1501, Team THRUST webpage
2005 IRI - Imagery and Design Award
2005 - 2006 BMR - Professional Grade Award
2006 BMR - Delphi Driving Tomorrow's Technology Award
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~ RogerR
~Da team that uses all tha rivets, Team #1501~
The FIRST Software Repository ~ Chief Admin
openFIRST ~ Project Supporter (Former editor)
DMOZ.org - FIRST - US Teams Section ~ Chief Editor
Unread 07-02-2005, 22:05
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
part of your tetra grabber Actually in general any really odd parts this year are going to be used for grabbing tetras because thats the only option other than drivetrain. I suppose there could be a couple other nifty ideas, but thats basicalyl all there is.
Team Website
Unread 07-02-2005, 22:08
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Looks like it's for a three prong claw mechanism
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 07-02-2005, 22:21
Stephen P's Avatar
Stephen P Stephen P is offline
Team Role: Mechanical
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
The bottom one looks a little like a bearing holder, but probably isn't. Anyhow it looks neat.
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 08-02-2005, 00:17
Andrew Hospodor's Avatar
Andrew Hospodor Andrew Hospodor is offline
Mentor
FRC #1072 (Harker Robotics Team)
Andrew Hospodor is on a distinguished road
Send a message via ICQ to Andrew Hospodor Send a message via AIM to Andrew Hospodor Send a message via MSN to Andrew Hospodor Send a message via Yahoo to Andrew Hospodor
I think it is too small for a tetra holder (look at the size of the carpet and compare to the piece). It is probably part of a gear box assembly that has had a lot of material removed to conserve weight. (that's my guess)
Andrew Hospodor
Team 1072
Electronics Subteam Leader
andrew@hospodor.com
1072 2005 Season
Sacramento Regional Champion
Judges Award - Silicon Valley Regional
Unread 08-02-2005, 00:22
24 Hours of LeMons?
They're just the claw joints, the larger piece is where the prongs are attatched. The smaller piece is attatched to a linear moving shaft which will allow the claws to open and close.
Unread 08-02-2005, 18:44
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Looks like parts to a motor and bearing assembly. Maybe part of a sub-system for a lift or arm?
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
