Go to Post First of all, please remember that while we often focus on winning the Chairman's Award, that it is the effort to win that matters. No one "loses" RCA... if you've worked your butt off all year in the spirit of the award, then you've already won before you even get to the regional. - dtengineering [more]
Unread 09-02-2005, 17:02
GAT-X105 STRIKE's Avatar
GAT-X105 STRIKE GAT-X105 STRIKE is offline
GAT-X105 STRIKE can only hope to improve
Hall Effect Sensors
Where is the program and where do you plug them in??
Unread 15-02-2005, 20:09
Re: Hall Effect Sensors
Need help...
Unread 15-02-2005, 23:25
the_undefined's Avatar
the_undefined the_undefined is offline
German FES
AKA: Felix Geisendörfer
#1648 (Gearbox Gangstas)
the_undefined has a spectacular aura aboutthe_undefined has a spectacular aura about
Hmm what do you mean is the program? You mean a code example?
Use Kevin Watson's Navigation Demo here and add a printf() for your Hall Effect Sensor output.
-> http://kevin.org/frc/
Where to plug it in?
You can decide that by setting up your code differntly.
In Kevin Watson's Demo it is:
1) The left encoder's phase-A output is wired to digital input
one and the phase-B output is wired to digital I/O six.
2) The right encoder's phase-A output is wired to digital input
two and the phase-B output is wired to digital I/O 8.
Read the Readme Files that come with it and you should be fine,
I hope that helps
bye
Felix@1648
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Hall Effect Sensor Example Code JJMax7 Programming 6 16-02-2005 02:38
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Hall Effect Source LaughingJack Programming 3 26-01-2005 05:28
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
