Go to Post “Nothing defines humans better than their willingness to do irrational things in the pursuit of phenomenally unlikely payoffs” - Scott Adams - 114Klaatu0x72 [more]
Unread 09-02-2005, 21:59
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Question Double calls of OpenADC()?
Tonight, I found something interesting relating to the gyro code and Get_Analog_Value().
The initialization of the gyro code (Initialize_Gyro()) calls OpenADC(), but there is no call to CloseADC(), so that the ADC remains open. Get_Analog_Value() calls OpenADC() and CloseADC(). If you call Get_Analog_Value() after calling Initialize_Gyro(), it will call OpenADC() before the last call was closed. There are no handles to these, so I assume that if you close one, you close all.
Does anyone know if this causes a problem? Or is it ok?
Unread 11-02-2005, 20:48
AKA: Jamie Bliss
Re: Double calls of OpenADC()?
After rewriting the the gyro/analog input code to use SetChanADC(), the code error light went away. Check my post in Unknown Blinky-light type Errors for the code.
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
Double Solenoid Leak Darksun Pneumatics 4 18-02-2004 22:52
Double Solenoid Wires Lord Nerdlinger Pneumatics 4 17-02-2004 19:54
FIRST Double Jeopardy! (8/27) EddieMcD Games/Trivia 2 28-08-2003 21:41
double solenoid gail OCCRA 0 11-10-2002 19:42
