Go to Post Wait, robot? We've been working on building a team. - rtfgnow [more]
Unread 10-02-2005, 00:36
Gal Longin's Avatar
Gal Longin Gal Longin is offline
Gal L.
#1578 (IsraBot)
Team Role: Leadership
Gal Longin is an unknown quantity at this point
Send a message via ICQ to Gal Longin Send a message via AIM to Gal Longin Send a message via MSN to Gal Longin Send a message via Yahoo to Gal Longin
Timers ?
I was going over the default code and i looked at delays.h . the file contains several functions that cause verious delays. the delays are measured in "Tcy" , what are those? are those Cycles or TeraCycles or TimerCycles ? and what do they mean in seconds?
"Only two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -Albert Einstein.
2005 Israel regional Finalist
2005 Israel regional Johnson & Johnson Sportmanship Award
2005 Israel regional Website Award
Unread 10-02-2005, 01:15
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Re: Timers ?
Instruction cycles. Each Tcy = 100ns.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 11-02-2005, 12:25
Gal Longin's Avatar
Gal L.
#1578 (IsraBot)
Re: Timers ?
-Kevin
Thanks !
Unread 11-02-2005, 12:49
Gal Longin's Avatar
Gal L.
#1578 (IsraBot)
Re: Timers ?
I have another question. suppose I use two or three encoders and in order to get the right value from them I need to use interrupts . can I use three different timers? or should i use the same timer but different interrupts?
Unread 11-02-2005, 17:05
FRC #2429
Re: Timers ?
What are the timers needed for?
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2005, 06:15
Gal Longin's Avatar
Gal L.
#1578 (IsraBot)
Re: Timers ?
-Kevin
for the encoders and the acceleration meter
Securing interrupt-driven timers Orborde Programming 3 10-02-2005 15:52
quick question: TIMERS Xufer Programming 58 18-03-2004 08:49
Library timers Ryan M. Programming 3 13-02-2004 09:02
How do you program timers? roberthan Programming 5 04-02-2004 02:18
What type of timers for autonomous? thoughtful Programming 1 09-12-2003 02:28
