Pneumatics-Code [and piston output length]
What is the output [piston length] of the given piston, in other words, how much does it extend?
Also, does the FRC_default.hex or FRC.hex supply functions for pneumatics,pwm signals for pneum. solenoids? |
Re: Pneumatics-Code [and piston output length]
A pistons length is about 2 " longer than the throw when in closed position. Therefore a 4" throw would give a 6" in length piston closed or 10" when open. This is a rule of thumb and not exact. Smaller throws still need minimum 4 "
I believe he is asking about how to control how long the piston extends in code. There is no easy way to do this without sensors, feedback, and multiple solenoids per cylinder. If it really is important, search multipositioning with cylinders for some help on the topic.
Actually, I was refering to the only given cylinder that came with the kit, the pneumatics manual doesn't give the specs for the given cylinder [not all those you can order].
Is there any difference between throw and stoke? P.S. Yes I was asking about pwm control: thank you for the coding tip [link]. |
| Updated: Serial Port Driver Code | Kevin Watson | Programming | 4 | 05-02-2005 18:39 |
| Kevin Watson's encoder code with RPM output | MaxM | Programming | 2 | 05-02-2005 00:06 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Rookie Programmer has question about the default code | DanL | Programming | 3 | 26-01-2002 19:59 |
