Go to Post Yes, I think we can all agree that bad people suck. - Joe Johnson [more]
Unread 10-02-2005, 14:46
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
basic pneumatic help needed
can someone please tell me how to do some basic things with the pneumatic thing? like turning the compressor on/off
also, wgere do i wire all the cables?
I tried searching, but all of the posts i found assume that the reader already knows the basis and needs to know something more compliciated.
Unread 10-02-2005, 15:06
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: basic pneumatic help needed
Have you read through pneumaticsfirst.org?
Unread 10-02-2005, 15:09
Anton's Avatar
Anton Povzner
#1581 (Element)
hey, thanks. I'll go check it out
Unread 10-02-2005, 15:24
Anton's Avatar
Anton Povzner
#1581 (Element)
I've been to there but I haven;t found anything about programming. are you sure there is something useful for me? or maybe I have just missed it?
Unread 10-02-2005, 16:02
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The "programming" consists of a single line of code. In the Buttons to Relays section of the default code, well-camouflaged among all the other copying of input switches to output relays, lies this small nugget:
Code:
  relay8_fwd = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
With this line in Default_Routine(), the pressure switch wired between ground and digital input 18, and the compressor wired between ground and the FWD output of a Spike connected to the relay 8 output, you're golden.
Pneumatic Gripper ruling Nitroxextreme Pneumatics 7 30-01-2005 13:04
Help needed for getting started! chantilly_team Programming 4 27-10-2004 08:29
[OCCRA]: pneumatic system greencactus3 OCCRA Q&A 1 21-10-2004 15:31
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
