Go to Post We are different, but in our differences we help the world continue to grow, change, become inspired. Different is NOT bad. Be true to your self, be weird, be dorky, be crazy, be a geek. :) - chellyzee93 [more]
Unread 11-02-2005, 21:26
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Third Encoder Channel
Yo. I'm new to encoders. From what I can understand, the default code at Kevin Watson's website only allows for two channels: the first channel uses analog inputs 1 & 6, and the second uses analog inputs 2 & 8. Does anyone know how to create a third encoder channel? Any help will be highly appreciated. Thank you.
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 11-02-2005, 21:32
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Third Encoder Channel
First of all, they are digital I/O channels, not analog. You can use DIO3-6 for the next interrupt input (phase A) and almost any unused digital channel for phase B.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 11-02-2005, 23:37
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It's not hard, but you do have to know what you're doing to get it right.
We're using three encoders. Two of them are on pins 1&7 and 2&8, using essentially Kevin's code. The third is on pins 3&9, with a few lines of interrupt initialization and service routine copied from Kevin's interrupts.c to dispatch the third encoder's handler when INT4 occurs. There is also an extra check to call the handler only when INT4 was triggered by a falling edge of the signal on pin 3. (That part of the code seems a little inconsistent, as if the input pin were going low and then high again before we had a chance to look at it. I'm considering wiring in a hardware pulse-stretch circuit to deal with it.)
To avoid extra interrupts that we would just have to ignore, we have nothing connected to pins 4-6.
Unread 12-02-2005, 00:51
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Cañada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Alan,
The simplest way to do this is with a D-type flip-flop (e.g., 74ACT74, 74HCT74, 74LS74, etc.). The encoder's phase-A signal goes to the the clock input and the RC interrupt input. The phase-B signal goes to the flip-flop's D input and the Q output goes to the RC digital input formally used by the phase-B signal. I prototyped this circuit and saw a pretty dramatic increase in the maximum count rate that the RC could handle.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 12-02-2005, 08:53
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
Originally Posted by Kevin Watson
Alan,
-Kevin
Three quick questions:
1) Must interrupts 3-6 be enabled/disabled as a package? i.e. you cannot ONLY enable 3, but not 4-6? I am using two encoders and the Hall Effect sensor, and need only 3 interrupts, and would rather not have to enable 6 of them.
2) If Q1 is true, and we enable 3-6, should we move the phase-B signal on I/O 6 to 7 in order to avoid unnecessary interrupts?
3) Does phase stretching circuit described in the threads above allow a faster count rate because it prevents the phase-B state from changing (to the wrong state) before the interrupt is serviced?
I know some of these should be pretty obvious, but Team 188 is running the Grayhill 63R256 encoders, and our count rates are pretty high. I'm hoping to stave off any interrupt issues that might arise =).
-SlimBoJones...
Unread 12-02-2005, 12:56
FRC #2429
Yes, but it's not a big deal. If you're not using the other three interrupts, just treat the interrupt the same way you would the first two. The only added step is to determine which edge caused the interrupt to fire off.
Yes, definitly. Just edit encoder.h to specify which digital input you've moved it to.
Yes, and it works really well.
The above circuit will increase your maximum count rate by a factor of four.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2005, 15:24
FRC #2429
Here's a schematic of the circuit described above.
-Kevin
Kevin Watson
http://kevin.org
Unread 13-02-2005, 17:10
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
hi, I tried doing the same thing, but I ran into problems because interrupts 3-6 are "ganged together". how do I reference one at a time? I couldn't figure out how to clear the interrupt flag either. basically, are there any magic lines of code to access one instead of all 4. we're going to need a third interrupt also (the arm), and since our team is pushing the building to the last minute, I can't afford have code messing up too much. thanks.
Unread 13-02-2005, 20:50
Software Architect
The magic lines of code are what I cribbed from Kevin's interrupts.c example.
Initialization is easy (easier than the other two interrupts, because there's no rising/falling edge selection). Testing to see which pin caused the interrupt involves remembering the state of PortB between interrupts and comparing the current state to see where they differ. My software also specifically checks to make sure the pin is in the proper state, so that I'm only calling the service routine on the desired edge of the signal.
Unread 13-02-2005, 23:32
AKA: Mr. Lim
Rookie Year: 1998
-Kevin
Built it =)
It runs great!!! Thanks!
-SlimBoJones...
Unread 16-02-2005, 10:16
kutty18 kutty18 is offline
#0234 (Cyberblue)
kutty18 is on a distinguished road
Send a message via AIM to kutty18 Send a message via Yahoo to kutty18
Hmmmm...is it possible to have a fourth encoder channel. How do I check for which Interrupt's (3-6) logic state has changed if I used a fourth encoder? Thanks.
Unread 16-02-2005, 10:50
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Here are our encoder files which will help you.
Jon
Mentor
Team236
Unread 16-02-2005, 14:49
#0234 (Cyberblue)
Thank you very much. I will test it tonight...
Unread 18-02-2005, 09:29
about_abot about_abot is offline
AKA: Gary Dettmers
#1008 (LugNuts)
about_abot is an unknown quantity at this point
Jon
Mentor
Team236
Jon,
Thanks for the help. I see you have a robot.h included in your user_routines_fast.c. Is there something in it that we would need to get it all to work?
-Gary
Team 1008
  #15   Spotlight this post!
Unread 18-02-2005, 10:47
Jon236's Avatar
AKA: Jon Mittelman
Rookie Year: 2000
Originally Posted by about_abot
Jon,
-Gary
Team 1008
We were unable to get the scripts to work as advertised. What finally worked was changing the list of commands into a switch...case series of statements that stepped through the commands in much the same way as the code in robot.c does. We used variables for the parameters which are then used by the called function. We did use the functions in robot.c and wrote additional ones for our arm.
Jon
Team236
"It's in the blood!"
encoder vs. motor stephenthe1 Programming 55 06-01-2005 22:07
Updated Encoder Code Available Kevin Watson Programming 2 04-01-2005 01:00
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
how to add steps in the provided encoder program for the edu Zaramel2002 Programming 3 11-02-2004 08:35
