Alright, I'm just a programming monkey, so my knowledge about wiring is a little... sketchy, to say the least.
![]() The thing is, every time we power up our robot, it trips the breaker panel. We can push the reset button, and everything works normally. Also, when we unplug every one of our motors, this does not happen - the panel is not tripped. (We only have our four CIMs for the drive train hooked up at the moment.) If we plug in any one of our CIMs, the breaker trips when we turn on the robot. (and works normally when we reset the breaker.) It's almost like the motors are drawing a huge amount of current right when we first power up. Anyone know what might be causing this? ![]() Last edited by Bleric : 12-02-2005 at 01:27. |
Re: breaker tripping on robot startup
Alright, this might be a stupid question, but do you have speed controllers between the breaker panel and your motors? If not, that would be your fix.
If you do have the speed controllers, I would check to make sure that the code has them in neutral (well...not full) when it starts. If it's not neutral, they'll start pulling current. Also make sure that you don't have any shorts anywhere. Connect everything (except the battery) and use a meter to check for continuity between power and ground (go through the battery connector). |
If it continues, suspect a short or defective breaker and fix the problem. IFI is always open for questions. |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| Shifting Gears | MBosompra | Technical Discussion | 71 | 23-07-2004 02:49 |
| what kind of robot will win? | Bcahn836 | Championship Event | 44 | 12-04-2004 00:02 |
| 60 amp breaker | Anne Lam | Technical Discussion | 10 | 10-01-2002 15:13 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
