Go to Post You have the right to remain silent. Anything you say can AND WILL be held against you (AND YOUR TEAM) in the court of public opinion. So choose what you do wisely. - Koko Ed [more]
Unread 12-02-2005, 10:07
Scott Shaw 237's Avatar
Scott Shaw 237 Scott Shaw 237 is offline
Hey! Must be da money!
AKA: Shaw 2
FRC #0237 (Sie-H20-Bots (T.R.I.B.E))
Scott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond reputeScott Shaw 237 has a reputation beyond repute
Send a message via AIM to Scott Shaw 237
Camera Problem Solved
On Page 8 of the Revised version of the camera manual under connections the pan reverse and the tilt reverse in the mode header area are backwards. This means that the pan reverse should really be tilt reverse and tilt reverse should be pan reverse according to the documentation. Last night the camera on our bot was running away from the green, and as soon as we changed those inputs it now successfully follows the colors.
2000 UTC Regional Winners Thanks 131 and 209!
2000 J&J Sportmanship Award
2002 NYC Regional Winners Thanks 549 and 358!
2002 Leadership in Controls Award
2003 Delphi Driving Tomorrow's Technology Award
2004 J&J Regional Winners Thanks 56 and 303!
2004 GM Industrial Design Award
2004 Motorola Quality Award
2005 New Jersey Regional Finalists Thanks 56 and 303!
2005 Radioshack Innovation in Control Award- FLR
2005 Radioshack Innovation in Control Award- NJ
2006 GM Industrial Design Award
2006 Delphi's Driving Tomorrows Technology Award
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Problem downloading any Camera code zuckie13 Programming 4 07-02-2005 20:32
camera problem miscar Programming 2 23-01-2005 12:06
Camera Color Recognition Problem? AnkurG Technical Discussion 3 20-01-2005 21:52
Camera Problem n_0163 Electrical 3 14-01-2005 21:10
