Go to Post GP is asking for something then having twenty people answer graciously. - synth3tk [more]
Unread 12-02-2005, 12:57
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Question Hall effect sensor Filtering
Hi,
I have read about filtering the Hall Effect sensor. I still dont understand the whole setup. Can some one please tell me which wire and resistors go to which exact pins. I will really appreciate it.
Unread 13-02-2005, 00:22
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
Re: Hall effect sensor Filtering
I am definitely NOT an EE, so I may have it all wrong, but I think the filtering you're talking about only applies to ANALOG devices. The Hall effect gear tooth sensor is a digital sensor, so I don't think it applies.
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 13-02-2005, 07:24
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
We are using the Hall Effect sensors without filtering and it works just fine.
I would only filter if you encounter a problem... JMHO...
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 13-02-2005, 09:18
Jigar Patel
AKA: Jigar Patel
Exclamation Re: Hall effect sensor Filtering
Yeah but what i heard is you need to place a 20 Ohms or 500 ohms resistor to filter the noise. I don't know anything about it and I heard people saying that so I was just wondering if it is necessary to place the resistor and if yes than where? Thanks guys for your reply
Unread 13-02-2005, 10:22
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Have you read the data sheet? http://www2.usfirst.org/2005comp/Specs/gths1.pdf
Obviously someone you trust has told you they are necessary, or you wouldn't still be questioning it after 2 people have said they aren't necessary in this thread. You could ask these people to fight to the death, and use the winner's suggestion, however I don't think that is likely.
Just asking if they are necessary isn't likely to help you make up your mind any better then you already have. A better question would be to ask what type of analysis did people do to decide that they were or were not necessary. From there you can make your decision on which argument seems more complete.
For the record, it can be just as necessary to filter a digital signal as an analog signal, particularly a high speed one.
Unread 13-02-2005, 11:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The low-value resistor is for filtering any noise on the power input to the sensor. It needs to be accompanied by a capacitor to ground at the power pin in order to do any actual filtering.
The five volt power supply from the Robot Controller is pretty clean, and probably doesn't need to be filtered. The RC digital inputs are of low enough impedance that the output signal from the sensor probably doesn't need to be filtered either. Unless you're running the wires from the RC to the sensor in parallel with motor power leads, I wouldn't expect you to have any noise problems.
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Where to place Hall Effect Sensors. Moloch Electrical 10 11-02-2005 16:47
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
Hall Effect Source LaughingJack Programming 3 26-01-2005 05:28
Code violation using Hall effect sensor pickle Programming 9 19-01-2005 00:10
