Go to Post If you see Navy ships in port, you're going to be fine. If you see ships pulling out, or no ships at all, go East. Fast. - Matt Howard [more]
Unread 13-02-2005, 14:06
Team 668 Team 668 is offline
#0668 (The Apes of Wrath)
Team 668 is an unknown quantity at this point
joystick sensitivity
i have been tampering with the code to make joysticks less sensitive. i cannot figure it out. it either has an error or nothing responds. does any1 kniw the code to make tha joystick less sensitive
Negative numbers? Calvin Programming 6 09-02-2005 10:46
Help with Joystick Axes and Sensitivity bglass Programming 6 06-02-2005 14:01
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
joystick problem archiver 2000 12 23-06-2002 23:08
