Go to Post Mark McLeod, one of the resident experts on compiler weirdness - Kevin Watson [more]
Unread 13-02-2005, 14:15
hawk_11's Avatar
hawk_11 hawk_11 is offline
FIRST Survivor
None #9999
Rookie Year: 2000
hawk_11 is an unknown quantity at this point
clib.lib not being read
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "main.c" -fo="main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_utilities.c" -fo="ifi_utilities.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "ifi_startup.c" -fo="ifi_startup.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "printf_lib.c" -fo="printf_lib.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines_fast.c" -fo="user_routines_fast.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\mcc18\bin\mplink.exe" "18f8520user.lkr" "C:\2005 Files\main.o" "C:\2005 Files\ifi_utilities.o" "C:\2005 Files\ifi_startup.o" "C:\2005 Files\printf_lib.o" "C:\2005 Files\user_routines_fast.o" "C:\2005 Files\user_routines.o" "C:\2005 Files\ifi_library.lib" "C:\mcc18\lib\clib.lib" /o"default code.cof"
MPLINK 3.90, Linker
Copyright (c) 2004 Microchip Technology Inc.
Error - could not find file 'clib.lib'.
Errors : 1
BUILD FAILED: Sun Feb 13 14:10:14 2005
clib.lib is not being found when it is right in the project. I compiled clib.lib and it says it is a syntax error. Fixing this syntax error leads to another, then another, and so on. Is this program defective?
Unread 13-02-2005, 15:08
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: clib.lib not being read
clib.lib should NOT be in the project folder. If it is you are not using the compiler correctly.
The MPLAB library path may not be set correctly.
Under Project -> Build Options -> Project
make sure the Library Path is set to where you have the compiler installed, e.g., c:\mcc18\lib
Unread 13-02-2005, 15:57
hawk_11's Avatar
FIRST Survivor
None #9999
Rookie Year: 2000
thanks, everything's up and running again
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
MPLink Error cloudago Programming 2 01-02-2005 23:00
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
programming error agenova Programming 1 20-02-2002 13:00
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
