| View Poll Results: how is your auton coming? | |||
| we can currently cap the center goal in autonomous |
4 | 6.45% |
| we can currently cap short goals in autonomous |
5 | 8.06% |
| we can currently knock down the hanging tetra in auton |
13 | 20.97% |
| we can currently block the field in autonomous |
13 | 20.97% |
| we currently have no automomous but plan to. |
24 | 38.71% |
| we currently cannot but plan to be able to cap the center goal in autonomous |
22 | 35.48% |
| we currently cannot but plan to be able to cap other goals in autonomous |
19 | 30.65% |
| we currently cannot but plan to be able to knock down the hanging tetra in auton |
15 | 24.19% |
| we currently cannot but plan to be able to block the feild in auton |
12 | 19.35% |
| we don't plan to have any automomous |
4 | 6.45% |
| Multiple Choice Poll. Voters: 62. You may not vote on this poll | |||
How is you auton coming?¿
Self explanatory. How is your autonomous coming? Answer honestly.
Re: How is you auton coming?¿
there's nothing for "we have autonomous but it just doesn't work"
I just finally got the camera working with my scripting tonight (don't ask me how because honestly it seems like it just started working on its own)... and I have a week to write automous providing no more bugs pop up O_O. So currently we have no automous written but definitely plan to use the camera... it's going to be a long long weekend...
Planning on breaking up the Auton mode into discrete chunks (technical term) of time (stages). Each stage is set via digital inputs (4 options each stage).
Alliance Color, Position on Field (a,b,c), and 2 pins for each auton stage = 2x3x4x4x4x4=768 Auton options Realistically, We may knock the stages down to 3 from 4. 2x3x4x4x4=192 Auton options. (time contraints for testing) ![]() |
*scratches head* ummm... we don't know yet??
Unfortunately, we have a case of 'the autonomous mode's ready, but the 'bot isn't. As I type, we're back to about square three and a half. The 'bot's not completely dismantled yet, but it's getting there. So until then... ![]() |
Hmmm.... web havn't quite started that yet... Only one week left, we'll start it in a few days... Plenty of time left, hey maybe the robot will even have the motors in then... but I can only hope so, otherwise the autonomous mode will be untested again, and will go into the competitions not knowing what we will do.
Ours is going pretty well. We worked for about 14 hours on it this weekend and I think it's really slose to being finished
Yea I was trying to do some simple things with it and then progress into multiple modes but my old code that worked was somehow overwitten by my new code that does not when they are 2 different names.
#10
Autonomous is completely ready... to be typed up, tested, debugged, and completed. Just got done with the flowcharts, the camera is calibrated and other necessary hardware just needs to be hooked on to the robot. Nothing big, I think. All that needs to happen is for the thought to fall in and settle so that we have autonomous, simply put.
#11
I have a question for ya'll. After the tetras are placed onto the field by the judges before autonomous, are we allowed to flip any switches on our controls to change our autonomous program(before the match begins obviously)? Thanks a bunch!
GO 1403!!! |
#12
"<G06> No team member may pass the Starting Line in their TEAM ZONE until the conclusion of the AUTONOMOUS PERIOD." - http://fjerboa.com/rules.php?inp=autonomous+controls+operator+interfa ce But you can have some switches set on it before you bring it up there... Not sure about if 'after the conclusion of the autonomous' means after that you cannot, but I have not really seen any other rules mention it... Last edited by AIBob : 15-02-2005 at 19:29. |
#13
another option is need for the poll:
[] ready to create the autonomus code but waiting for the reast of the team to finish their last bits of teawks to the robot. or something long the lines. ![]() (sry if any misplellings spell check not working) |
#14
I smartened up this year and wrote a totally modular autonomous program. So, all I need to do is load the code, check whats wrong, change #define's, and repeat.
As for what we are doing... we have no set amount of programs. We input a set of parameters into the bot (starting position, offense/defense, center/side goal, vision) and the robot figures out what to do. When all said and done, I believe there are about 22 different options for autonomous mode, and hopefully they all work to plan. Got all this weekend to debug tho. ![]() |
| Auton Cam scaning question... | Zalumaskov | Programming | 0 | 04-02-2005 11:01 |
| auton vids | ejSabathia | Robot Showcase | 3 | 09-03-2004 10:13 |
| testing Auton and IR sensors at events | KenWittlief | General Forum | 2 | 08-03-2004 16:40 |
| auton mode running motors incorrectly | BK36 | Programming | 2 | 12-03-2003 02:43 |
| Can't figure out auton mode | TangoBravo1318 | Programming | 1 | 20-02-2003 10:06 |
