Go to Post It's not very graciously professional to point out the un-gracious professionalism in others. - Taylor [more]
Unread 15-02-2005, 13:19
farmer farmer is offline
Tired Mentor
AKA: Matt
#1108 (Panther Robotics)
farmer is an unknown quantity at this point
Help with auton switching code
Late night coding isn't working. We hooked up a binary switch to 4 digital inputs(tied to ground). And added the following code as a test;
void User_Autonomous_Code(void)
static unsigned int mode = 0;
/* Initialize all PWMs and Relays when entering Autonomous mode, or else it
will be stuck with the last values mapped from the joysticks. Remember,
even when Disabled it is reading inputs from the Operator Interface.
pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
relay1_fwd = relay1_rev = relay2_fwd = relay2_rev = 0;
relay3_fwd = relay3_rev = relay4_fwd = relay4_rev = 0;
relay5_fwd = relay5_rev = relay6_fwd = relay6_rev = 0;
relay7_fwd = relay7_rev = relay8_fwd = relay8_rev = 0;
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
mode = ((8*!digital_io_04) + (4*!digital_io_03) + (2*!digital_io_02) + (!digital_io_01));
/* mode = 2; */
switch ( mode )
case 0: /* Do nothing */
break;
case 1:
time++;
if (time < 114) {
pwm04 = 150;
else if (time < 152)
pwm04 = 127;
relay4_rev = 0;
else if (time < 570)
pwm01 = 127;
pwm03 = 127;
break;
If we set "mode" equal to 2 or any other number the switch code works fine. But apparently the binary to digital conversion setting "mode" is not because the robot doesn't move. Thanks for any help.
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
heres the code. y this not working omega Programming 16 31-03-2004 15:18
