Go to Post Band geek FIRST geeks = uberparty! - Nuttyman54 [more]
Unread 15-02-2005, 14:08
Shinsa Shinsa is offline
AKA: Lyhn
#1303 (Wyoming Aftershock)
Shinsa is an unknown quantity at this point
Problems with tracking
When testing our tracking code, we run into a little problem. We are testing tracking by using the method in the camera manual which says to select a color with the joystick in port 2, and to pull the trigger on the joystick in port 1. When we do this, sometimes our robot goes to the color we are tracking,and works just fine, but most of the time, our robot just spins in circles or just swerves left and right, and does not approach our robot. I have tried changing the steering comp values and the speed comp values in the code, but so far no dice. If any one can help us, it would be appreciated. I also hope this makes sense to you guys.
Unread 07-02-2010, 10:48
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Re: Problems with tracking
Are you guys using Ni Labview?
Unread 07-02-2010, 14:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
In 2005, they'd have been using C in MPLab, and they'd have been using the CMUcam. I'm pretty sure Shinsa's problem is no longer of interest.
PC problems. . . opnickc IT / Communications 5 12-01-2005 16:53
Robot Rodeo - fixing control problems Gary Dillard Off-Season Events 7 26-10-2004 00:46
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Radio problems -- not archiver 2000 1 23-06-2002 22:23
