Go to Post Wow. Just wow. Never did I think the mentor built robot debate would make it on to a tv show. - ASD20 [more]
Unread 15-02-2005, 19:28
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Springs, Bungees, Counterweights
I've been watching this board for a couple of weeks and haven't seen a proposed design for an arm that uses either a counterweight or a spring system on the arm itself.
The problem with a counterweight, of course, is that if it is mounted on the arm it raises the CG and does not contribute to the other functions of the 'bot. I suppose the counterweight could have been mounted on a 1/2-height tower using a 2-1 pulley-and-cable system, but that would be clumsy, still add weight up high, and only apply half the downward force as a weight connected through a 1-1 purchase. Of course, if there were a backwards-extending arm just as long as the main arm, you could hang a fairly small weight on the back (see construction cranes). You would still have the high CG problem.
If you committed to a backwards counterbalance arm as long (or almost as long) as the main arm, you could use bungee cord material or a spring to store energy when the arm is descending that could be used to help lift the arm-and-tetra. There are some issues to be solved regarding the effective length of a spring and whether it could be used over the effective length of the arm's motion, but there are ways to work around this. A spring-over-shaft design, sort of like a roll-up garage door spring, might work pretty well.
If you think about it for a few minutes, it would be trivial to design a counterbalance that could be extended automatically after measurement.
Anyway, our team rejected the concept of counterbalancing forces (grumble, grumble), and went with a straight lifting arm system. I am curious if anyone is planning to use this sort of stored energy (smart teams), or considered it and rejected it. Talk amongst yourselves.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
using gas springs? needed? ajlapp Technical Discussion 2 20-01-2005 21:25
[OCCRA]: motor brush springs greencactus3 OCCRA Q&A 1 28-09-2004 20:56
Constant Force Springs - Data Sheets? Ben Piecuch Kit & Additional Hardware 1 06-05-2004 19:00
springs hi_im_sean Technical Discussion 4 23-01-2003 19:05
springs CharlieWilken Technical Discussion 3 30-01-2002 19:39
