Go to Post but look at the bright side, you will now be able to size 1/4-20 nuts with your forearm and i doubt there are many people who can say that :p - Greg Needel [more]
Unread 15-02-2005, 22:32
TMHStitans TMHStitans is offline
Robot Operator-2005
AKA: Eric
#1474 (Tewksbury Titans)
TMHStitans has a little shameless behaviour in the past
Question Programming motors with joystick buttons
I am a relatively new programmer on a second year team. I was wondering if anyone knows if it is possible to program a window motor using the joystick buttons. What our team would like to do is to program our joystick so that when we press one button, the arm motor goes forward. When we press another button, we want the motor to go back. I do not know how to translate the relay outputs to a pwm output which would make the motor move. I tried writing an if statement that makes the pwm produce an output if a button is pressed, however nothing happens. I have performed countless searches for this information. The only threads I found talked about operating pnuematics using the joystick buttons, not motors. I do not know how to wire or program the relays so as to get a pwm output. I would appreciate any help. Thanks.
Lead Programmer, Team 1474
Unread 15-02-2005, 23:01
incognito_NICK's Avatar
incognito_NICK incognito_NICK is offline
hidden in the corner
AKA: Nick Ferreira
#0179 (Children of the swamp (swampthing))
incognito_NICK will become famous soon enough
Send a message via ICQ to incognito_NICK Send a message via AIM to incognito_NICK
Re: Programming motors with joystick buttons
you have the right idea about using an if statment.
what you can try is something like this:
Code:
if(p1_sw_trig==1)
   pwm01=254;
else if(p1_sw_top==1)
   pwm01=0;
else
 pwm01=127;
Unread 15-02-2005, 23:10
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Same sort of thing would work if you have the window motor on a spike.
Code:
if (p1_sw_trig==1)
	relay2_fwd = 1;
	relay2_rev = 0;
else if (p1_sw_top==1)
	relay2_fwd = 0;
	relay2_rev = 1;
else
	relay2_fwd = 0;
	relay2_rev = 0;
Unread 15-02-2005, 23:16
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Or, alternatively:
Code:
pwmxx = (127 + (127*p1_sw_top) - (127*p1_sw_trig));
Replace xx with the pwm output you'll be using for the motor. In this case, pressing p1_sw_top will make the motor go full forward, p1_sw_trig will make it full reverse, and pressing both will do nothing.
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
Unread 15-02-2005, 23:29
stephenthe1 stephenthe1 is offline
stephenthe1 is on a distinguished road
hey,
I always wandered, when you press a button on a joystick (say the top button or trigger), does it "remember" it was pressed and hold a value of 1? I don't really understand this. otherwise, for the guy who posted this forum, he would have to be holding down the trigger, which seems like it would be problematic. do you know what I mean? how does that work.
Unread 21-03-2005, 21:07
dm0ney's Avatar
dm0ney dm0ney is offline
Will Code For Food (Food Optional)
AKA: Deepak Mishra
None #0217 (The ThunderChickens)
dm0ney will become famous soon enough
Send a message via AIM to dm0ney
Originally Posted by stephenthe1
hey,
When a button is pressed on a joystick, it is not remembered. If the motor was to be driven for some time and the user did not want to hold the button until the desired point, a flag would have to be used.
The flag would be set to one when the button is pressed which would enable code controlling relay ouputs or pwms. Once a desired outcome happens, the flag would have to be reset. The outcome could be a pot position being reached, an encoder count value, a set amount of time from either Kevin's clock or a clock variable incremented every program cycle, or even the ORIGINAL BUTTON pressed on the joystick.
Alumni
Team #217, The ThunderChickens
Student, Class of 2009
California Institute of Technology
Using the extra buttons on the joystick. Code\\Pilot Programming 7 04-12-2004 19:30
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
Programming the second joystick in PBASIC archiver 2001 2 24-06-2002 00:25
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
