Go to Post Change your process to change your product. - Justin Montois [more]
Unread 16-02-2005, 09:30
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Rookie Year: 1998
Adam Krajewski is on a distinguished road
Re: homemade speed controlllers (for school project)
Originally Posted by Denman
Has anyone ever made their own speed controllers for the robots?
Note this is for a School Project.
I haven't built one, but the most developed plans for speed controllers I've found is the OSMC:
The official site for them is here: http://groups.yahoo.com/group/osmc/
You can buy kits to build them here: http://www.robot-power.com/osmc_info/
I've wanted to build one, but I don't have a need for a 50V, 160A speed controller.
"My favorite programming language is solder."
- R A Pease
Unread 16-02-2005, 10:33
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
[voice=codger]I was programming robots and wiring speed controllers before you young'uns were born.[/voice]
In 1981, I was the principal programmer for a group building a radio-controlled robot (featuring a TV camera and two-way audio) for an engineering open house event at the University of Illinois. The electronics guy designed and built a 16-step pwm speed controller, using a separate mechanical relay to switch between forward and reverse. We tested everything out using a single 12-volt car battery and it worked well, if a bit slow -- the motor and circuitry were intended for a 24 volt supply. When we were satisfied with the results, we added the second battery. It went fine until we gave it full throttle, at which point the speed control circuit caught fire.
One of the diodes neatly unsoldered itself from the board and broke the circuit before we could react. Replacing those diodes with heftier ones fixed the problem, and the Synton Amateur Radio Club Telepresence Robot worked fine thereafter.
Unread 16-02-2005, 12:46
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Wow,
It must be the last week before ship as everyone is on edge. Stephen, Mike Betts is a good source for control. You do need to come up with a list of what you want to do. Do you need fine control of speed, direction control, full torque with speed control, etc. If you just want to change speed and don't care about anything else, you can find lots of variable voltage circuits that might work and are easy to build for beginners. You might want to hook up with an amatuer radio club for some added help. There is some really active clubs in Britain
Al
WB9UVJ
www.wildstang.org
________________________
Unread 16-02-2005, 15:45
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
cheers al! you are one of the people everyone knows and respects here
it would seem so (in relation to your first sentence), i have just found out that one of my mates is really into building remote controlled planes (and hes on the robotics team....)
ANyway, after the builds finished etc you'll hear from me more
stephen
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 16-02-2005, 16:00
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
There is some great information on speed controllers and design at:
http://www.mcmanis.com/chuck/robotic...sc2/index.html
In fact I recommend the entire site for those interested in robotics and electronics.
Jason
Unread 17-02-2005, 01:27
Don Reid Don Reid is offline
Don Reid will become famous soon enough
I wanted to try some experiments with small motors and a processor
producing PWM signals. I found a nice H bridge circuit at Digi-Key,
the LMD18200 from National. You feed it a pwm signal and power
for up to 3A at 12-55 volts. Of course you need a heat sink and some
filter caps at those levels.
Don Reid
Unread 11-03-2005, 19:25
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Adam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to beholdAdam Y. is a splendid one to behold
Send a message via AIM to Adam Y.
What type of motor do you want to use and what am I going to use this motor for is the most important question that you probably need to know. Moving a heavy object involves the use of a motor that we all know and love. Moving an object with percision would benefit most from either a stepper motor or a servo motor. If you want a motor that is going to last a long time brushless is the way to go.
Here is a website that I obtaind from searching google about speed controllers:Website
If either a public officer or any one else saw a person attempting to cross a bridge which had been ascertained to be unsafe, and there were no time to warn him of his danger, they might seize him and turn him back without any real infringement of his liberty; for liberty consists in doing what one desires, and he does not desire to fall into the river. -Mill
Unread 15-04-2005, 09:40
Denman's Avatar
AKA: Stephen Denman
Hi again all
an update
I decided to make something easier for my school project, however there is a couple of people from the lower year who would like to make a couple, for this event. http://www.extremefightingmachines.c...cambridge.html
Basically we don't wnat to use any of the first equipment due to how expensive and precious it is, so we will be using a remote controlled car reciever, and a couple of home made speed controllers. The reciever gives out a pwm output to whatever it drives, and we used it beforein a previous featherweight, but with 2 victors.
So firstly, we need to decide how much current and what motors etc it will drive. They will most probably be window screen wiper motors, from a local junkyard. Anyone who would like to help and suggest stuff is most welcome, and it would be great to see a FIRST team thrash the destruction style teams
Denman
Unread 15-04-2005, 10:14
Unsung FIRST Hero
Rookie Year: 1996
Stephen,
I am not sure how your cars are laid out but in the US, the motor drives both wipers and is relatively powerful. I would guess it may run stall current as high as the Chalupa or Drill motor, about 100 amps. Your homemade controllers should be designed to handle that much current.
Al
WB9UVJ
www.wildstang.org
Unread 15-04-2005, 11:12
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
The game looks fun
good luck!
Team 302
Unread 15-04-2005, 11:51
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Stephen,
One option might be to use a chopper circuit from a cordless drill. An example is DeWalt part number 152274-10, Switch, VSR, available at www.dewaltservicenet.com for US$41.14. You would have to make mechanisms to actuate the trigger and reversing switch, but that might be simpler and cheaper than building your own compact high-current motor speed controller.
Good luck.
Richard Wallace
since 2003
Unread 18-04-2005, 11:07
Denman's Avatar
AKA: Stephen Denman
Originally Posted by Al Skierkiewicz
Stephen,
last year we used some from a ford fiesta, they ran fine on a victor 554... the may not be a robot to put them in now.... depends what happens on this wednesday, as we havn't started on it. but we'll see
Right now i'm just researching some basic therory
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
