Go to Post If winning that individual match is more important to you than being there in the first place, then I believe you've got your priorities in the wrong spot. - Tom Bottiglieri [more]
Unread 16-02-2005, 14:01
capenga's Avatar
capenga capenga is offline
Penga boy
AKA: Giovane
#1156 (Under Control)
capenga is an unknown quantity at this point
Send a message via ICQ to capenga Send a message via MSN to capenga
Float in MPLAB
How can I use float variables in MPLAB?? I've tried, tried, tried, but really don't know how to do it...
Someone knows how?
Ignore alien orders.
Unread 18-02-2005, 06:44
cbolin's Avatar
cbolin cbolin is offline
Programming & Electrical
FRC #0342 (Burning Magnetos)
cbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to beholdcbolin is a splendid one to behold
Re: Float in MPLAB
Hi,
Not sure what you are really asking. Are you trying to create a float type variable, load it with a value and use it in an equation? Are you getting errors when you do this?
Here is a short snipped of code using a float. Let us know if you are asking something different.
Code:
float number = 2.314;
float answer;
answer = number * 1.5;
Regards,
ChuckB
Team 342 Programming & Control Systems
Good luck and have fun!
New math functions? KVermilion Programming 8 17-01-2005 10:38
MPLAB Variable Simulator? Chris_Elston Programming 3 18-02-2004 12:08
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
