Go to Post Look guys, I am telling you for the fourth time - you are NEVER going to earn your official "Geek" certificates if you keep spelling "pwned" with an "O" in it! - dlavery [more]
Unread 17-02-2005, 01:27
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Code Assistance
Hey all!
This is my first attempt at writing some code for our autonomous (wow! Were getting off to a late start (::looks at calendar: 4 days til ship! )
Anyway, I'd like everyone to browse through and offer some comments.
Now, this isn't the *best* code in the world, I mainly tried to writeup everything into one packet, so some stuff might be messy, and I know I can remove a few variables, but I wrote them in for neatness's sake.
Here it is!:
Code:
//Init all our Variables
int time=0; //define a counter in the beginning
int seconds=0; //set up a variable for the time in seconds too!
int step=0; //Define our steps too!
int tracking = 0; //Define our tracking watcher
int tea_time = 0; //A temporary time holder :) Its Tea time!
int start_pos = 0; //Field startup Position
int left_sw_hist = 0; //Left Switch History
int rght_sw_hist = 0; //Right Switch History
int fwd_spd = 175; //Tracking forward speed
//Maintain our start position data from the RC
if (rc_dig_in11 == 1)
start_pos = 1;
if (rc_dig_in12 == 1)
start_pos = 2;
time++; //Increment the time!
seconds = time / 1000; //Get the time in seconds!
//Reset all drive/arm variables
pwm11 = pwm12 = 127;
relay2_fwd = relay3_fwd = relay4_fwd = 0;
//Set up the Pneumatics to keep the charge
  relay1_fwd = !rc_dig_in01; //Run the pump if the system is low on pressure.//
  relay1_rev =0;
if (step == 0) //Drive out onto the field a bit
  pwm11 = pwm12 == 150;
   if (time == 500)
   step++;
if(step==1) //Begin the track sequence, track the tetra until contact
   camera_init(45,19,121); //Init the Camera with the calibration values
   camera_auto_servo(1); //Turn on the Auto Servo Feature
   camera_find_color(GREEN); //Seek Green
	if (rc_dig_in02 == 1 || rc_dig_in03 == 1) //If one of the skirt switches trip, go to the next step.
	 if (rc_dig_in02 == 1) //Record Left History for the next step
	 left_sw_hist = 1;
	 if (rc_dig_in03 == 1) //Record right history for the next step
	 rght_sw_hist = 1;
	tea_time = time;
	step++;
if (step==2) //Align the tetra with the "grabber"
  if (left_sw_hist == 1 && rght_sw_hist == 1)
  left_sw_hist = 0;
  rght_sw_hist = 0;
  step++;
  if (left_sw_hist == 0 && rght_sw_hist == 1)
  pwm11 = 175;
  pwm12 = 130;
   if (time == tea_time + 150)
   left_sw_hist = 0;
   rght_sw_hist = 0;
   step++;
  if (left_sw_hist ==1 && rght_sw_hist == 0)
  pwm11 = 130;
  pwm12 = 175;
   left_sw_hist = 0;
   rght_sw_hist = 0;
   step++;
if (step==3) //Raise the arm to loading stand height and check to see if the tetra is held. If so, proceed. Otherwise, retrack the tetra.
relay2_fwd = relay3_fwd = 1; //extend the arm
if (rc_dig_in06 == 1)
  if (rc_dig_in04 == 1)
  step++;
  if (rc_dig_in04 == 0)
  relay2_fwd = relay3_fwd = 0;
  relay4_fwd = 1;
   if (rc_dig_in05 == 1)
   step = 1;
if (step==4) //Track up to the goal until contact is made
camera_find_color(YELLOW); //Seek Yellow
 if (rc_dig_in10 == 1)
  relay2_fwd = relay3_fwd = 0; //Stop extending the piston if its fully extended
	 if (rc_dig_in02 ==1) //Record Left History for the next step
	 left_sw_hist = 1;
	 if (rc_dig_in03 ==1) //Record right history for the next step
	 rght_sw_hist = 1;
	 tea_time = time;
	 step++;
if (step==5) //Almost done! Wait until the last few seconds to trigger the capping sequence!
 pwm11 = pwm12 = 130;
  if (seconds == 13) //Lets try giving it 2 seconds to play it safe for now...
  step++;
 if (left_sw_hist == 1 && rght_sw_hist == 0)
 pwm11 = 130;
 pwm12 = 140;
  rght_sw_hist = 1;
 pwm11 = 140;
 pwm12 = 130;
  left_sw_hist = 1;
if (step==6) //The Final step! Plant that tetra on the goal in the last few seconds!
relay4_fwd = 1;
if(camera_track_update()==1)
   if (cam.size>0)
     tracking=1;
   else
      tracking=0;
if (step==1 || step==4) //If we're in a tracking step, drive!
 if(tracking==1) //Follow the color if we see any of it!
  pwm11 = Limit_Mix(2000 + fwd_spd + cam.pan_servo - 127);// Ok now put some single joystick drive code here using the variable cam.pan_servo as the x axis of the joystick, and a constant value as the y axis
  pwm12 = Limit_Mix(2000 + fwd_spd - cam.pan_servo + 127);
 else
  pwm11 = 63; //Seek to the left if all else fails!
  pwm12 = 175;
  if (start_pos == 1) //If we started on the left half of the field, turn to the right
  pwm11 = 145;
  pwm12 = 100;
  if (start_pos == 2) //If we started on the right half of the field, turn to the left
  pwm11 = 100;
  pwm12 = 145;
I used some tidbits of code posted here on CD to start with. Now, I just wrote this (at 1am) so I won't get to test it til tomorrow, but I'm crossing my fingers that it'll work ok! It did compile!!!
Any comments would be great. Just understand I'm not making it neat or extremely well laid out just yet, I'm trying to get the main process down
Thanks!
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 17-02-2005, 07:13
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
Re: Code Assistance
Hmm.... Interesting method.
But note that variables 'time' and 'step' will reset to zero each time that you go through this loop.
Make them 'static signed int time = 0, step = 0;'.
You probably could cut down the length of that a lot, and make it a lot more modular so that you could have quick changes during the compeptitions (whenever allowed), and have a better layout of the code.
- from B B frank
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
heres the code. y this not working omega Programming 16 31-03-2004 15:18
