Go to Post I guess we'll just have to resort back to our original plan of telepathy. - seg9585 [more]
Unread 17-02-2005, 10:28
Moloch's Avatar
Moloch Moloch is offline
Moloch can only hope to improve
kevin watsons scripting . . .
I have kevins nav code, and I have my drive commands entered and those work just great. Now I just need some help with the autonomous scripting. I know that its supposed to be easy, and from what I have read, it seems as though it is very easy. But after looking through the code, and reading tons of things on scripting and coding, I still need some help. I need someone to give me some code that will get my scripting commands in the command.h file to start running in auton. I dont know how to start the auton to test it. I dont really know antything about auton at all. PLEASE help me get started on this! Time is running out, I only have 5 days left!
Unread 18-02-2005, 00:49
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: kevin watsons scripting . . .
All you need to do is put robot_control(); in user_routines_fast.c
Code:
  while (autonomous_mode)   /* DO NOT CHANGE! */
    if (statusflag.NEW_SPI_DATA)      /* 26.2ms loop area */
        Getdata(&rxdata);   /* DO NOT DELETE, or you will be stuck here forever! */
        /* Add your own autonomous code here. */
		robot_control(); //call automous mode
        Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
        Putdata(&txdata);   /* DO NOT DELETE, or you will get no PWM outputs! */
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 18-02-2005, 17:52
Fuzzypanda007 Fuzzypanda007 is offline
ferret's rawth
#0564 (Digital Impact)
Fuzzypanda007 is an unknown quantity at this point
Send a message via AIM to Fuzzypanda007 Send a message via Yahoo to Fuzzypanda007
It actually isn't really hard at all. I have been able to make a small code, but it hasn't worked for my bot yet :/ . Anyway, to use it, go to the top and under the part that says something like "declare all variables here" put "static unsigned int t;" Then, in the area mentioned by Chakorules that says "add your own autonomous code here" put this:
t++;
if (t < 95) //turn left for 2.5 seconds
pwm01 = 95; //left motor goes in reverse
pwm02 = 150; //right motor goes forward
else if (t < 285) //go straight for 5 seconds
pwm01 = 150;
pwm02 = 150;
else if (t < 380) //turn right for 2.5 seconds
pwm01 = 150;
pwm02 = 95;
else //stop after 10 seconds
pwm01 = 127;
pwm02 = 127;
I( am not sure if this will work 100%, considering this is my first year as a freshman, but if you put this part of the code in a loop, is really should work. well, i hope this helped. see you at the competition.
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
2005 Autonomous Scripting Manual Anthony Kesich Programming 31 17-02-2005 17:30
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Kevin Watson's Kick-off Demo Code! Mr. Lim Programming 27 22-01-2005 03:38
